Goce Posted October 11, 2016 Report Posted October 11, 2016 I want to convert my fans to work of a thermal switch in the radiator, the original system never work properly and now as i've removed the A/C i like to convert it to a 2 fan 2 speed system, got a termal swich with 3 pins for 2 speeds, now i need the diagrams or if some one has done it before any advice. Quote
SRDT Posted October 11, 2016 Report Posted October 11, 2016 The test connector is used on the AC equiped cars, it's also useful to wire a switch on the dashboard. Quote
Goce Posted October 11, 2016 Author Report Posted October 11, 2016 Do you know if the wire numbers are the same for this diagram and 405 SRDT ? Quote
SRDT Posted October 11, 2016 Report Posted October 11, 2016 I can't really tell but probably not. Quote
Goce Posted October 14, 2016 Author Report Posted October 14, 2016 9 hours ago, my3AWDgst said: I got diagram for US cars. If you have it post it or mail it to me. Quote
imaS Posted October 14, 2016 Report Posted October 14, 2016 Haynes manual has some wiring diagrams for fan controls. You can get a copy from the T16 website. http://405t16.free.fr/Doc_tec.htm Quote
my3AWDgst Posted October 15, 2016 Report Posted October 15, 2016 I can take good clean pictures of it for you. Quote
Stewart Posted January 15, 2017 Report Posted January 15, 2017 I have plenty of information for you. No 1 information is, Yellow with green trace wire will go to earth/negative terminal somewhere. (Thankfully Peugeot used colour for earth wires. back then.) No2. If you disconnect the Brown 2 wire coolant temp sensor , both fans should go on High speed. Quote
Goce Posted January 15, 2017 Author Report Posted January 15, 2017 Thank you Stewart, you can see in my build thread i've already found them and will connect them when i install the radiator support because it's all attached to it. Quote
