Martin Hicks Posted October 5, 2015 Report Share Posted October 5, 2015 Just want some ideas to steer me in the right directionthanks for any and all ideas. That is front right headlight. Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted October 5, 2015 Report Share Posted October 5, 2015 You can go to your local parts store and purchase that connector then just join wires to correct location. Easy as that. Quote Link to comment Share on other sites More sharing options...
Martin Hicks Posted October 5, 2015 Author Report Share Posted October 5, 2015 Problem is locating the correct wires to each other (slight color blind problem ) Quote Link to comment Share on other sites More sharing options...
andrethx Posted October 6, 2015 Report Share Posted October 6, 2015 do you have the wiring diagram for your car? the wires are numbered, if you unravel that electrical tape sufficiently you will find the numbers stamped on the wires. then you will know which wire is which and you can attach a new connector as savo suggests. is this for the red 89 405? if you don't have the diagram, savo or i might have it... andré Quote Link to comment Share on other sites More sharing options...
Bean Posted October 6, 2015 Report Share Posted October 6, 2015 Do you have a wrecker nearby? If so then get the connector and 12" of wiring to go with off another car and use that. Should be able to use the other headlight wiring to wire the right wires from the "new" connector to the wires on the car. (Pattern should be different enough to differentiate? ). Good sealed crimps are best, otherwise I like to solder and heat shrink connections. Rabin Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted October 6, 2015 Report Share Posted October 6, 2015 I can see in the picture just fine which one goes where. 1) Green/yellow on your left (Green/yellow is always ground in Peugeots) 2) Black middle. 3) Brown to your right. Quote Link to comment Share on other sites More sharing options...
Martin Hicks Posted October 6, 2015 Author Report Share Posted October 6, 2015 Discussing this thread with the wife, just got the fish eye and said she would do it. She good at being my supervisor and keeping my temper in check. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
