nick@nite Posted March 6, 2013 Author Report Share Posted March 6, 2013 Maybe a little too excessive Quote Link to comment Share on other sites More sharing options...
Bean Posted March 7, 2013 Report Share Posted March 7, 2013 ^^^ = Because Racecar... Are you setting up CO2 for extra cooling or is that a water bar on the IC? Rabin Quote Link to comment Share on other sites More sharing options...
norcal505 Posted March 8, 2013 Report Share Posted March 8, 2013 that is a sick throwback! Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 8, 2013 Author Report Share Posted March 8, 2013 ^^^ = Because Racecar...Are you setting up CO2 for extra cooling or is that a water bar on the IC? Rabin That was a Meth line, IC kit came off a WRX that my father bought at the auction a few years ago. The WRX had a brand new Cosworth 2.5L block with 2.0 heads.... It was to good to pass up. I found a stock 2.0L engine and returned the car back to stock. Now having a spare engine for my father's STI. His engine is using some oil... It's been stressed a few times. No blow by but its using oil. It's makes more power than he's willing to take it a lot of times still. We're trying the Total 10w60 oil. I just don't want any lag Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 15, 2013 Author Report Share Posted March 15, 2013 Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 20, 2013 Author Report Share Posted March 20, 2013 Bye Bye framerail for now... Quote Link to comment Share on other sites More sharing options...
Bean Posted March 21, 2013 Report Share Posted March 21, 2013 What ARP studs were those - and did they press right in? I bought some Honda ARP studs for my hub conversion set up, but ended up using different ones in the 1st attempt, but if I need to run spacers I'll likely redo the rear flanges and install the ARP studs. Rabin Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 21, 2013 Author Report Share Posted March 21, 2013 ARP 12X1.25 press in and had to tack weld the back .The kit is for a WRX. Quote Link to comment Share on other sites More sharing options...
Bean Posted March 21, 2013 Report Share Posted March 21, 2013 Tack welded since they were a bit loose? Or tack welded as a racer precaution? Nice move on replacing the frame rail too - it'll be much stronger with a fresh piece welded in. Rabin Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 21, 2013 Author Report Share Posted March 21, 2013 The rail was still 3/4 of an inch shorter on the left side, and wasn't plated very strong..... Chris Putzier is having another Bi op on his neck and isn't doing very well.... His 3rd time around now....Studs were a slight bit loose. We also cut the tops off the OE lugz and re tapped them all the way through. Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 23, 2013 Author Report Share Posted March 23, 2013 Straight and reinforced now.... Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 23, 2013 Author Report Share Posted March 23, 2013 JK Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 25, 2013 Author Report Share Posted March 25, 2013 Pushed the car out for the first time in a week. Went over to Kalescustom, loaded the danielson engine.Took off the Timing covers, installed all new chain, tensioner, and both slide pads. Zero slack now Headstuds will be installed tomorrow with using the OE headbolts washers. Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 26, 2013 Author Report Share Posted March 26, 2013 Pearl engine bay and gloss black subframe, painted the headlight lenses again white.New front crank seal, re drill and tapped a bunch of thread holes. Installed headstuds to 70 then to 80 ft. lbs, with the consideration of fine thread VS. course thread... @ 80 the nuts hardly moved from 70. Torque is torque, and we all agreed on that. How it sits now.Tomorrow we have to screw around with fitting the headers. Go get the intake again so we can figure out an alternative bracket setup for the Alt. and P/S pump/res. Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 27, 2013 Author Report Share Posted March 27, 2013 Polished the V/C today and fit the headers with BMW metal o-ring gaskets. BP7ES Spark plugs. now working on the intake. Quote Link to comment Share on other sites More sharing options...
Bean Posted March 28, 2013 Report Share Posted March 28, 2013 Awesome update! Absolutely love that last shot of the motor with the header. Any plans to have it ceramic coated to keep some of the heat inside? Or are you just going to wrap it? And did you guys figure out how to do the 60-2 trigger wheel for the VEMS yet? Rabin Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 28, 2013 Author Report Share Posted March 28, 2013 Awesome update! Absolutely love that last shot of the motor with the header. Any plans to have it ceramic coated to keep some of the heat inside? Or are you just going to wrap it?And did you guys figure out how to do the 60-2 trigger wheel for the VEMS yet? Rabin My father doesn't really believe in wrapping on turbo cars. The header beside the little rust on the bottom still has the coating. Talked with Jason Russell yesterday. He says the Hall effects on the distrib works, although not as accurate as a crank trigger. Time will tell. Quote Link to comment Share on other sites More sharing options...
Bean Posted March 28, 2013 Report Share Posted March 28, 2013 Distributor I did up with a one window wheel just for cam timing for VEMS - it's not for the ignition. Rabin Quote Link to comment Share on other sites More sharing options...
nick@nite Posted April 2, 2013 Author Report Share Posted April 2, 2013 Well got the P/S pump figured out. Rotated a ZDJL pump and used the N9T pulley. Using an Audi 3.0 p/s hose. Stock N9T belts fit tight.Still have to cut and mod the intake for the injectors. CIS injectors have longer nozzles... Quote Link to comment Share on other sites More sharing options...
nick@nite Posted April 3, 2013 Author Report Share Posted April 3, 2013 Throttle body and intake are done, pulled the sleeves out for the injectors to fit. Quote Link to comment Share on other sites More sharing options...
Bean Posted April 3, 2013 Report Share Posted April 3, 2013 Sweet throttle body... Looks great man - can't wait to see what numbers this seet up can put down. Rabin Quote Link to comment Share on other sites More sharing options...
nick@nite Posted April 3, 2013 Author Report Share Posted April 3, 2013 Thanks Rabin for the usage of the TB! Tomorrow we'll be starting the process of installing the engine into its rightful place.... Quote Link to comment Share on other sites More sharing options...
nick@nite Posted April 23, 2013 Author Report Share Posted April 23, 2013 Received the Diamond racing rims about a week and a half ago.Matted the trans/ puck clutch together today. Found out that the right stock engine mount won't work with the headers.... Quote Link to comment Share on other sites More sharing options...
andrethx Posted April 24, 2013 Report Share Posted April 24, 2013 would love to see pics of the diamond rims when you get everything mounted up! andré Quote Link to comment Share on other sites More sharing options...
Stewart Posted April 24, 2013 Report Share Posted April 24, 2013 How goes the install? Quote Link to comment Share on other sites More sharing options...
