Just a general update.
Sold the Mint Cali silver 505 to Peter Paine. He loves it. On the way back from the Citroen meet, #25 blew a front wheel bearing. Had to get it towed back home. Thanks AAA....
The Burgandy GL Auto needed a Radiator, so #25 got the Howe rad. #25 had an Automatic radiator in it so we lucked out.
RockAuto had a new Raybestos right rear caliper for $65, #25's caliper was sticking. L/R we put on a good used one from Tommy.
We shimmed the rear end yesterday. #25 handled like poop. Toed out. Now we toed the rear wheels in. It's getting a front crank seal too. installing the other Recaro seat The Blue 505: Same thing with having to shim the rear end from being toed out. It wore the r/r tyre almost down to the cord on the inner edge. Very poor handling. New VDO priming pump
New Brakemaster cylinder last week. Right side rack boot
Burgandy 505
Radiator and re did and cleaned B+ wire to the starter. 89 Wagon New Front pads and rotors Cleaned and greased Needle strut bearing on the R/F
288K and the Headgasket blew right after the fresh brakes. Going to slapping a different head on, that has very small hairline crack in between 2 and 3. It should be fine for that car. My burgandy GL is sitting at the moment. Needs front pads Front Crank seal I took the VC off to replace the V/C gasket. My father wants to do a Valve adjustment but hasn't had time yet. And then Diagnose the no start issue. Dani Hillclimb car getting solid motor mounts fabbed up nothing else to report.....
