Trevor Posted August 30, 2005 Report Share Posted August 30, 2005 What do you guys think? I wonder how hard it would be to accomplish.. hmm. Quote Link to comment Share on other sites More sharing options...
Bean Posted September 2, 2005 Report Share Posted September 2, 2005 What do you guys think? I wonder how hard it would be to accomplish.. hmm. ← I thought the same thing... Best thing I came up with was using two gears, machine one of them as the center with a threaded hole on each spoke, and a machined flat area. The second one would need the machined flat on the back side and an elongated hole to match up with the hole. Not sure if you could use the guts from an off the shelf one as I've never seen a metal one. It would have to be machined VERY nicely - but definitely possible. Hard to put into words - but you should get my drift... Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 2, 2005 Author Report Share Posted September 2, 2005 Yea i think we both have the same line of thought on this one. Hmm... I may snoop around work tomorrow and think about it a bit more. We have the right tools for the job, but i think it would be a difficult project to do right. As you said it would have to be done very well as a lopsided cam gear wouldn't be too optimal... haha. Quote Link to comment Share on other sites More sharing options...
august Posted September 4, 2005 Report Share Posted September 4, 2005 there was some N9T mechanic at sunset coachmen years ago who said there was some mustang 5.0 aftermarket cam pulley which would work on the N9T.. i'll have to dig into some resources Quote Link to comment Share on other sites More sharing options...
V-M Posted September 14, 2005 Report Share Posted September 14, 2005 I'll take pictures of my sample of adjustable gear. Only those 7mm bolts are missing V-M Quote Link to comment Share on other sites More sharing options...
JunktionFET Posted September 14, 2005 Report Share Posted September 14, 2005 A tech that used to work at Sunset Coachmen (JP) had the idea of using the cam adjustment eccentrics from a smallblock GM V8 I believe. He found that the stock bolt holes on the N9T cam gear just needed to be machined to accept the commonly available cam adjustment eccentrics. Quote Link to comment Share on other sites More sharing options...
webmaster Posted September 14, 2005 Report Share Posted September 14, 2005 I'll take pictures of my sample of adjustable gear. Only those 7mm bolts are missing V-M ← I'm excited to see what you have come up with! Quote Link to comment Share on other sites More sharing options...
V-M Posted September 26, 2005 Report Share Posted September 26, 2005 Cam gear pictures added, not fancy but working 4 Deg in each side from 0 point. V-M Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 26, 2005 Author Report Share Posted September 26, 2005 Cam gear pictures added, not fancy but working 4 Deg in each side from 0 point.V-M ← I can't seem to find the pictures on your site. Could you provide a link? Quote Link to comment Share on other sites More sharing options...
V-M Posted September 26, 2005 Report Share Posted September 26, 2005 Oh... Sorry. Now they are. V-M Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 28, 2005 Author Report Share Posted September 28, 2005 ahh, nice! I still would like to do one up for myself one of these days. So many projects with this car, it's hard to keep up with myself. Quote Link to comment Share on other sites More sharing options...
august Posted September 28, 2005 Report Share Posted September 28, 2005 what would be REALLY slick is to machine the upper timing cover manifold so you wouldn't have to take it off every time you'd want to adjust it.. being it isn't the quickest job in the world.. then again, a whole with a plate on the front of the manifold may cause trouble too though being the distributor gear is in _front_ of the damn cam gear.. hmmmmm Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 28, 2005 Author Report Share Posted September 28, 2005 haha yea that would be excellent to set it up so it can be easily set without dealing with timing cover removal. hmmm.. Quote Link to comment Share on other sites More sharing options...
V-M Posted October 20, 2005 Report Share Posted October 20, 2005 Some update on this one this 4 deg was not enough... exhaust valves were hitting pistons (more info on this new engine topic). I did remove adjusting and replace it with original gear and sifted one tooth in advance. I needed 8 deg and one tooth is 10deg -> so now it is 2 deg in advance -> no problems V-M Quote Link to comment Share on other sites More sharing options...
