All Activity
- Last week
Got a set thanks to John Waller in Northumberland, who found me a Glacier AE set over there. Also have a guy in Ontario having a look in his old stock and I'll buy that set as well for future considerations. It's just a question now of when they arrive determining when I can resume work.
- Earlier
wadehilts started following 1987 505 Turbo Revival
Wow this was a very helpful thread for me! I had the exact same problem with error code 4. I just revived a car that had been sitting and the alternator VR is bad, producing over voltage. I likely have a damaged ECU as a result. Very grateful you did all the heavy lifting for me on this. I'll swap in a good alternator and then a spare ECU and see what happens!
Handbuch WHB XD3 XD3T deutsch.pdf HANDBUCH XD3TE.pdf
Was planning to put the bottom end together last weekend but I either misplaced my new mains or didn't order any. Small setback in the scheme of things, so I cleaned the sealing surfaces of other parts in anticipation of the eventual assembly. Powder-coated elements: Timing cover with Kugelfischer injection pump drive wheel visible. This surface was gooped up with Permatex and gasket residue from the 2021 assembly. I did have the rod bearings.....
Oh, and a word about asbestos sealing. The originals contained asbestos. There is a torque for the cylinder head screws. For those without asbestos you need a slightly higher tightening torque. This puts strain on the thread in the head! I avoid this by sealing with asbestos.
Hello, I have a question! Were there taillights with red indicators for a 504 Station in the USA or Canada? I would like to install one of these on my station. If so, is there anyone who would let me have one? Thanks Jens
Hello everyone, I read the whole thread again after months. I would like to post the manual for the XD3TE. The data for choosing the head gasket and its notches are also given there. And a lot of other very interesting things. Jens Handbuch WHB XD3 XD3T deutsch.pdf HANDBUCH XD3TE.pdf
Hello i would like to find a detailed procedure of an Xn6 head gasket replacement. where can I find it? thanks a lot tom
91MR2 replied to 91MR2's topic in Member build threads
Finished the grinding/scraping/preparations today on the Sportwagon. Next week I will treat the metal with Chassis Saver (similar to por-15), and into the paint shop it goes. This was the day I was least looking forward to, so glad it is over... -
Hey guys, been a bit... Re. the red car, got the injectors out and cleaned them, re-installed them, fired right up and nothing leaking now, so that's a good start. Still need to install the new driver's side front brake hose and want to service the rear calipers, but that's for another day... Re. the SW, finally getting ready to have a little paintwork done. Started today by scraping some rusty scale of the bottom of the hatch, as well as the driver's side doors. Fortunately the car is very solid, so this is a very basic cleanup and respray of the damaged areas, unlike the red car which needed some more invasive surgery... Stay tuned... -
Hey guys, Thank you very much for your answers. I thought it was like that too. I think I've already read about it here. But I wasn't sure! Here in Germany I can't get an answer to this question! They're mostly just posers. Laughing at people who want to make drastic changes to your vehicle. At most they change the polish of the paint... Ok, that's pretty harsh, but it feels like it! ;-). In any case, I want to change the ratio. And that raises some questions because I want a long ratio differential from a 505 with more than 100hp. ...and then for the front and rear. So there is independent suspension at the front and a rigid axle at the rear. I will try it! The engine should have enough power (130 hp) for the higher ratio gearing. The wheels are also a little bigger. Instead of 195/80 16, 225/85 16. I wish I was further along. Our house fire set everything back a bit. All the best Jens I will report to you...
I can find 3 EZ200K variants: 5945.26 (0 227 400 033) form 01/86 up to 01/87 5945.46 (0 227 400 128 N9TEA 176W with boost control ?) from 01/87 up to MOD 89 5946.49 (0 227 400 153 N9TEA Wagon ?) since MOD 89 From the outside these ECUs are not visually similar to the Volvo or Saab EZKs, they seem to be closer to Alfa Romeo's EZ201K (75-Milano 1.8 turbo) and EZ212K (164/GTV 2.0 V6 turbo).
Seem at kat versions has this EZ 200 K which looks information from knock sensor and lamda info and has no those pressure switches. I have some factory books about kat version. those are in germany lang but has good pictures.
All the US models have cats though. Iv not seen that pressure switch before and Iv gone looking for it before a few times.
The dual curves ignition box and pressure switch are used on the 160 and 180 hp engines with intercooler and no cat. I think US models should have a Bosch EZK ignition ECU unless it's a non intercooled car.
Don't think so. In US the coil is mounted vertically right there and I dont see anything like that.
Bean started following Differential. Exchange of The ratio.
505 sedan and wagon differential internals (ring and pinions) are supposed to be interchangeable as well. I’ve never done it, but I’ve heard it done from wagons to sedans for rally cars to get higher ratio gearing. Rabin
Should be there? next to gauge sender? Number 3 is switch, note at for me it was stuck cause there was moisture which was reacting with sensor internals and rusted inside.
Hey folks, Is there anyone in the forum who knows whether the inner workings of a 505 differential fits into that of a 504? Or from a 505 sedan to a rigid axle from the 505? Thank you and best regards from Bavaria. Jens
I have seen those curves and information about a pressure switch somewhere before but I think that is for European cars. I dont think we have that pressure switch in america
Bump
