christophe4559 Posted June 5, 2016 Report Share Posted June 5, 2016 I'm looking for the pushing rod. Placed between the foot pedal and theTransmitter(Issuer) of clutch. Thank you ! Quote Link to comment Share on other sites More sharing options...
Goce Posted June 5, 2016 Report Share Posted June 5, 2016 The push rod looks easy to be made, as a design seems bad design, you can use a heim joint and a rod, and that should outlast the car. Quote Link to comment Share on other sites More sharing options...
Bean Posted June 5, 2016 Report Share Posted June 5, 2016 Hi Christophe, I fixed mine a few years back - no room for a heim joint Goce... It's worked beautifully ever since. Rabin Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 5, 2016 Author Report Share Posted June 5, 2016 Very good solution i try it soon , thank you Bean ! Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 5, 2016 Author Report Share Posted June 5, 2016 Did you have the mensurations off the original pushing rod ? diamètre , tall , .... Quote Link to comment Share on other sites More sharing options...
Bean Posted June 5, 2016 Report Share Posted June 5, 2016 Hi Christophe, I used 1/4" steel round stock, which matched the 1/4" oil impregnated sintered bronze bushings perfectly. I used the old rod as the pattern so there was no need to take measurements. Used a vise to clamp as I bent the rod, careful to protect it from jaw marks. Rabin Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 6, 2016 Author Report Share Posted June 6, 2016 okayyy ! So you use a new steel rod ! And how can you Manufacture the kneecap at the end ? My problem is in fact that i haven't the old busching rod ! I lose it ! And one more question 1/4 means 1.4 inch, then means 3.556 centimeter ? Quote Link to comment Share on other sites More sharing options...
Bean Posted June 6, 2016 Report Share Posted June 6, 2016 Hi Christophe, 1/4" steel round stock = 6.35mm diameter rod. 6 or 7 mm rod should work fine, but use whatever fits the bushing you use/find. Not sure which end you mean - I used a vise to hold the rod and I bent it 90 degrees. The end that goes into clutch master I ground to a smooth rounded tip. Rabin Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 7, 2016 Author Report Share Posted June 7, 2016 Ok it's clear ! thank you so much. For the end of the rod i mean "machining a ball". So how tall is the busching rod ? his emplitude ? Quote Link to comment Share on other sites More sharing options...
Bean Posted June 7, 2016 Report Share Posted June 7, 2016 Hi Christophe, You can measure easily how long the rod should be - hold clutch pedal up and then measure to the inside of the clutch master. Rabin Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 8, 2016 Author Report Share Posted June 8, 2016 For sure ! But we shouldn't let a little area ? Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 8, 2016 Author Report Share Posted June 8, 2016 I found this http://www.michaud-chailly.fr/index.php?ent_id=1&cat_id=1&ni1_id=19&ni2_id=114&ni3_id=296&ni4_id=2114&csaction=site%2Fentite%2Fcatalogue%2Fdetail_technique_filtrer&ent_id=1&cat_id=1&ni1_id=19&ni2_id=114&ni3_id=296&ni4_id=2114&colonne=7&filtre=8 I'm going to make an outside threading 12 x 1.5 Quote Link to comment Share on other sites More sharing options...
Bean Posted June 8, 2016 Report Share Posted June 8, 2016 Rod should fit snug, and maybe just pushing a little little bit so it's in tension, but not loose to where it can move around. Link just takes me to a main page - no details that show me anything. Rabin Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 9, 2016 Author Report Share Posted June 9, 2016 ok i undertstand. then we have this manufact : http://www.rationalstock.fr/materiel/fr/coussinet-a-collerette-auto-lubrifiant-en-bronze-fritte/30051000002/0/ Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 9, 2016 Author Report Share Posted June 9, 2016 Thank you. My problem is on the right way in France because of you too ! http://club505.forumpro.fr/t5690p30-recherche-tige-de-poussee-embrayage#101576 Quote Link to comment Share on other sites More sharing options...
Bean Posted June 10, 2016 Report Share Posted June 10, 2016 The machining the narrow part isn't really needed... I haven't been on the French site in a while - I need to spend some time there and get caught up. Rabin Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted June 10, 2016 Author Report Share Posted June 10, 2016 Perhaps but i do it, it's not difficult to made. Quote Link to comment Share on other sites More sharing options...
christophe4559 Posted July 2, 2016 Author Report Share Posted July 2, 2016 Done ! Quote Link to comment Share on other sites More sharing options...
