dan68rs Posted September 26, 2009 Report Share Posted September 26, 2009 Wanted to say hi! I just picked up a 86 505 turbo on friday, 79k miles, clean car but not drivable yet. they guy that i bought it from said the trubo was bad, i do see alot of oil but not in the intake tubes and the turbo seems to be very tight. I pulled the plugs out last night and one of the plugs was broken, it was missing the ceramic on the inside of the plug. im going to check the cyl to see if there is any damage with a bore scope but hopefully the main trouble was the plugs. Im in Birmingham Alabama, not sure if there is anyone around this area, i know i have never seen any around. Quote Link to comment Share on other sites More sharing options...
Bean Posted September 27, 2009 Report Share Posted September 27, 2009 Welcome to the board Dan! 79K miles it's just a baby... Good luck sorting it out - there's a ton of info on this site, so read away. Biggest thing to watch for with these is that they are known for a weak head - it cracks between the exhaust valve and the water jacket. Combustion pressurizes the cooling system - blows out a rad or a hose, and the thing over heats. So if the cooling system is intact and there's coolant in it - that would be a good sign. Hopefully it is just the plugs! What a sweet deal that would be! BTW - hopefully it came with some mags. There was a post on the yahoo group Peugeot-L for some later flat spoke mags just in case you didn't get the proper wheels with it. Rabin Quote Link to comment Share on other sites More sharing options...
norcal505 Posted September 27, 2009 Report Share Posted September 27, 2009 wow, thats sick. great find. 74k is much less than what I'm rolling on, sub-300k. haha never seen a turbo car with the GL rims on it before..interesting.. welcome aboard! Quote Link to comment Share on other sites More sharing options...
dan68rs Posted September 27, 2009 Author Report Share Posted September 27, 2009 I was wondering about the wheels, i guess someone swapped them out or something, im going to have to look for some because i dont like these to much Quote Link to comment Share on other sites More sharing options...
Bean Posted September 27, 2009 Report Share Posted September 27, 2009 Yup - those are the steelies with hub caps off the GL model - great for winter tires, too bad you have no winters... You can likely sell those for decent $$ to older Subaru (<89 loyale and others use the same bolt pattern)guys if you can't find a pug buyer for them. The alloy's make a big difference in both the look and handling. I prefer the older 15" alloy as they have more of a pattern - shouldn't be hard to find a set. There's a guy with a whack of Pugs in Georgia - so that might be close enough. (Join the yahoo group Peugeot-L and post there) Any more details on the car? Does it have a sunroof? 5-sp? Hopefully you get it sorted - they're a great drivers car. Rabin Quote Link to comment Share on other sites More sharing options...
dan68rs Posted September 27, 2009 Author Report Share Posted September 27, 2009 Thanks i will check out that site too. the car does have the sun roof and is an auto, i would rather a 5 speed but it will work. i will get some more pics in the next few days. Quote Link to comment Share on other sites More sharing options...
Peugeottogo Posted September 28, 2009 Report Share Posted September 28, 2009 Thanks i will check out that site too. the car does have the sun roof and is an auto, i would rather a 5 speed but it will work. i will get some more pics in the next few days. Is it a GL turbo? Not many were produced Jeff Quote Link to comment Share on other sites More sharing options...
Bean Posted September 28, 2009 Report Share Posted September 28, 2009 Sunroof means it's not a GL-Turbo... GL-Turbo's had no sunroof and roll up windows. Rabin Quote Link to comment Share on other sites More sharing options...
Peugeottogo Posted September 28, 2009 Report Share Posted September 28, 2009 Sunroof means it's not a GL-Turbo... GL-Turbo's had no sunroof and roll up windows. Rabin Yep your right, Makes for less weight Quote Link to comment Share on other sites More sharing options...
norcal505 Posted September 29, 2009 Report Share Posted September 29, 2009 Yep your right, Makes for less weight but isn't fun on hot sunny days, i.e yesterday in northern california Quote Link to comment Share on other sites More sharing options...
Bean Posted September 29, 2009 Report Share Posted September 29, 2009 They still had AC Rob... I quite like my GL-Turbo without sunroof - it's amazing how much quieter they are on the highway. Once I flush mount the windshield it'll be even better. Rabin Quote Link to comment Share on other sites More sharing options...
norcal505 Posted September 29, 2009 Report Share Posted September 29, 2009 I wish my a/c worked....but that's a couple hundred I could use in better ways.... Quote Link to comment Share on other sites More sharing options...
dan68rs Posted September 30, 2009 Author Report Share Posted September 30, 2009 well it runs but the turbo does seem to be bad, im going to check to make sure the drain is not clogged. Seeing alot of oil coming out of the turbo. Does anyone know which relay is the starter relay? Im not getting any vlt to the wire at the starter. Quote Link to comment Share on other sites More sharing options...
Bean Posted October 1, 2009 Report Share Posted October 1, 2009 Turbo - You can get rebuild kits for these turbos quite cheap. They're easy to rebuild as long as there's no damage to the turbines. I've done a couple and they're dead easy. Starter relay - not sure there is one as one of the failure points is the ignition switch. The fix is to install a relay that uses the small wire at the starter as the signal wire on the relay and then swiches a fresh 12V supply to the starter. Some don't like the relay fix - but it makes sense to do to me. Rabin Quote Link to comment Share on other sites More sharing options...
dan68rs Posted October 1, 2009 Author Report Share Posted October 1, 2009 Turbo - You can get rebuild kits for these turbos quite cheap. They're easy to rebuild as long as there's no damage to the turbines. I've done a couple and they're dead easy. Starter relay - not sure there is one as one of the failure points is the ignition switch. The fix is to install a relay that uses the small wire at the starter as the signal wire on the relay and then swiches a fresh 12V supply to the starter. Some don't like the relay fix - but it makes sense to do to me. Rabin I was wondering about re-building the turbo myself. as far as the starting, i checked for volt at the small starter wire but not getting anything. I did find the topic about the starter relay though. Quote Link to comment Share on other sites More sharing options...
Bean Posted October 1, 2009 Report Share Posted October 1, 2009 The usual symptom is that you get a starter solenoid click when you try to start - the small wire isn't giving a full 12V to actuate the solenoid and it doesn't start. So if you're getting nothing at all when the key is turned to start - then you either have connector issues, ground issues, or the ignition switch is totally gone. I had a 504 and a 505 that I rigged up with toggle switches and a push button starter - so if you want to do it on the cheap it is possible. Rabin Quote Link to comment Share on other sites More sharing options...
