peculiar33 Posted March 11, 2008 Report Share Posted March 11, 2008 Okay. I have had to park the 505. The right front strut tower has failed (rusted through). I know these things are extremely rare, but if anyone has a set they can part with, or knows of someone who does, I am in dire need. Thanks everyone. btw: I finally found my camera Quote Link to comment Share on other sites More sharing options...
Bean Posted March 12, 2008 Report Share Posted March 12, 2008 Your best bet is to find some in the wreckers from somewhere south... There've been some links and contact info for some wrecking yards in Cali - so hopefully you can find some through there. You might also want to try online parts finder - I just tried it and got quite a few hits for struts. Hopefully you can find a used set for a decent price close by. Another option is to pull them and have the rest of the spring perches machined off (or have at it with an angle grinder) and then get some coil over collars put on. Spring rate at the front is ~ 100 lbs - so you could get some springs to fit. The top would be a bit more difficult - but not too bad. Rabin Quote Link to comment Share on other sites More sharing options...
peculiar33 Posted March 12, 2008 Author Report Share Posted March 12, 2008 Thanks Rabin. Quick question: what years are compatible with the 86 turbo, and can I use struts of of a non-turbo if I change the springs? Quote Link to comment Share on other sites More sharing options...
Bean Posted March 12, 2008 Report Share Posted March 12, 2008 Struts from any 505 will fit up to 87' (has to be the one piece strut and hub assembly) - but the turbo struts have a different camber built into them. Not critical - but so you know. The turbo's also have different internals and damping settings - so if you use lesser 505 front strut the car will ride a bit on the soft side - just make sure to at least use the turbo springs. Hopefully you'll find a replacement from a turbo though. If you do end up getting different ones - I'd be interested in the rusted ones - I just want the internals. Rabin Quote Link to comment Share on other sites More sharing options...
peculiar33 Posted March 12, 2008 Author Report Share Posted March 12, 2008 I have George from Sunset Coachmen looking for something that can be made to work. Calls have also been made to several recyclers in NC and AL. We shall see. I am looking at the FSM, and there are two different procedures for removing and refitting these. Do I have the detachable swivel bearing? I'll keep you in mind Bean, should be no problem if I can get this thing back on the road. Thanks. Quote Link to comment Share on other sites More sharing options...
norcal505 Posted March 13, 2008 Report Share Posted March 13, 2008 now that you have some pics of that? any pics of the car??!! please! Quote Link to comment Share on other sites More sharing options...
peculiar33 Posted March 13, 2008 Author Report Share Posted March 13, 2008 Hey Rob, Here are a couple from the driveway. I'll take some proper shots when all four wheels are on the ground. Quote Link to comment Share on other sites More sharing options...
nick@nite Posted March 14, 2008 Report Share Posted March 14, 2008 I thought my uncle just took the strut housing out of the STX he just strip. he told me he didn't though Quote Link to comment Share on other sites More sharing options...
norcal505 Posted March 25, 2008 Report Share Posted March 25, 2008 get it fixed yet? any new shots? Quote Link to comment Share on other sites More sharing options...
peculiar33 Posted March 25, 2008 Author Report Share Posted March 25, 2008 As a matter of fact, it went in yesterday. I ended up getting the STi struts from Texas, and they are going to swap the springs and inserts from the dead turbo struts. Also getting new tie rod ends, sway bar bushings, and brakes. That should pretty much do it for the front end. I'll get more pics when I get it back and have a chance to wash it. Quote Link to comment Share on other sites More sharing options...
