Johnny Posted November 20, 2007 Report Share Posted November 20, 2007 Does anyone know if the clutchplates on the turbo diesel engines are identical to the ones in the gas turbos? I'm guessing that they are, because the gearbox is the same (as far as I know). Quote Link to comment Share on other sites More sharing options...
Bean Posted November 20, 2007 Report Share Posted November 20, 2007 I'm 99% sure they are as well... Best way would be to call a shop and see if the same part number comes up... Rabin Quote Link to comment Share on other sites More sharing options...
Peugeottogo Posted November 21, 2007 Report Share Posted November 21, 2007 This is what I found: N9T> PG-205553 XD2&3> Small spline PG-205504 XD2&3> large spline PG-205501 Jeff Quote Link to comment Share on other sites More sharing options...
V-M Posted November 23, 2007 Report Share Posted November 23, 2007 I have this 505TD 230mm set made by LuK currently. Only bearing have to be replaced of that set. That normal LuK set will hold ~600Nm. V-M Quote Link to comment Share on other sites More sharing options...
Johnny Posted November 23, 2007 Author Report Share Posted November 23, 2007 Ok, I think we can conclude that the 505 TD clutchplate isn't the same as the one for 505 TI. V-M, is that set the same as a OEM-set or is it an upgrade-kit? What bearing do you need for it, TD-ones or some other? Quote Link to comment Share on other sites More sharing options...
V-M Posted November 25, 2007 Report Share Posted November 25, 2007 Ok, I think we can conclude that the 505 TD clutchplate isn't the same as the one for 505 TI. V-M, is that set the same as a OEM-set or is it an upgrade-kit? What bearing do you need for it, TD-ones or some other? Well, I can't say difference between those plates... That's OEM kit for TD version. Bearing is different than TD one. So original will hold 560Nm and this LuK was mentioned at it will hold +20% than original. V-M Quote Link to comment Share on other sites More sharing options...
