holtet_ Posted October 12, 2023 Report Share Posted October 12, 2023 Good evening Lads and Ladies! Long story, short: I've been lucky enough to catch a Peugeot 605 SR 3.0L V6. Currently its under making/rebuilding of a Motorsport Car. I've completely removed everything from the rear of the engine bay and all the way to the luggage trunk. During the removal of the whole electric circuit underneath the dashboard, i discovered that there isn't too much wiring that the engine needs to run, compared to the mid 90's - early 2000's engines. So i figured that i'd remove all of the wiring within the coupè. The only thing that remains to get this enging running agian is to find out which few electrical components that need electricity. I've seen mulitple threads where you take the 605's ZJP (12v) V6's and rebuild them into the 505's. So my question is how do you do you wiring, because you can't just reuse everything from the 605... If you know what needs electricity and what don't need it, i would love to hear from you. I would also really appreciate it if anybody has the wiring diagram for either 605 or the wiring diagram for the ZJP 12v 3.0L V6 itself Love, Holtet_ 387864935_280350238233745_7073928812031387284_n.mp4 387788720_999522114491485_6288455617281836927_n.mp4 Quote Link to comment Share on other sites More sharing options...
Goce Posted October 12, 2023 Report Share Posted October 12, 2023 I have a ZPJ 3,0 on a pallet from my 605, i've wired it to run, about 10 years ago. Now is not accessible but when i get some spare time i'll try to dig it out and take couple pictures wich cables are for power. Quote Link to comment Share on other sites More sharing options...
SRDT Posted October 13, 2023 Report Share Posted October 13, 2023 You can look for Citroën XM wiring diagrams, the engine and ECU should be the same: http://doc.aqrweb.org/Moteur_PRV_24S/Citroen_XM/XM-V6.pdf https://citroen.tramontana.co.hu/en/system/files/circuit_diagram.pdf Quote Link to comment Share on other sites More sharing options...
