august Posted November 9, 2006 Report Share Posted November 9, 2006 a shop in florida has listed an ebay auction to get rid of their complete inventory of peugeot parts. i've talked to the owner and he said everyhting is boxed up, and he's be willing to ship, but local pickup is preferred (as you can imagine). i'm going to try to post the list of parts he has, hopefully the formatting doesn't all out of shape. Link to eBay auction The full excel spreadsheet can be downloaded: here Sheet1 Quantity Part Number Description 1 40.6 1 42.45 fr. Brakeins 6 42.48 2 42.5 10 205.14 washer 1 218.5 37 243.01 1 349.88 1 626.86 3 803.06 camshaft 1 816.07 2 818.18 1 818.18 5 820.03 screw 2 820.15 2 827.17 4 906.93 washer 1 907.14 8 939.03 push rod 8 950.13 half cone 11 956.11 valve 2 956.14 vstem seal 1 1109.45 fuel filter 4 1170.1 GAKSET 6 1170.14 gasket 1 1172.62 1 1172.75 1 1180.34 1 1201.61 1 1201.76 1 1201.85 1 1253.12 1 1259.11 hub 2 1339.66 2 1351.53 1 1563.98 bracket 1 1564.94 3 1573.2 1 1573.76 1 1621.34 value 1 1621.63 3 1621.78 joint 1622.91 1623.3 1 1625.68 clamp 10 1628.37 grommet 2 1628.41 clamp 3 1628.8 1 1629.88 2 1639.25 romg 1 1647.44 6 1654.24 spring 1 1665.15 value 2 1667.12 screw 10 1680.47 O ring 10 1710.19 stock exha 4 1710.34 gasket 2 1710.36 gasket 3 1710.61 gasket 3 1710.7 gasket 4 1710.96 3 1713.17 clamp 2 1713.25 exaust cl 2 1713.31 clamp 4 1713.56 half clamp 10 1714.44 rubber stud 3 1714.44 7 1735.33 4 1735.57 strap 8 1735.67 strap 8 1735.78 strap 1 1755.22 strap 1 1755.42 strap 4 1755.44 supp blast 1 1755.52 suspens. Strap 4 1755.53 1 1798.64 1 1906.02 fuel filter 1 2086.1 cylinder 1 2203.09 gasket 3 2203.1 3 2209.26 gasket 1 2444.64 cable 3 2829.03 spring 1 3293.59 boot protect 1 3640.25 2 3817.5 ARM 3 4003.63 3 4003.69 PLUG 1 4011.43 verin 5 4018.42 clip 1 4020.24 T UNION 1 4047.03 nec joint valve 1 4057.11 EYE 20 4058.25 1 4059.07 articulation 1 4059.07 articulation 1 4066.27 SOUFFLET 1 4066.28 1 4241.73 BRAKE SHOES 2 4246.7 brake disks 1 4250.22 BRAKE PADS 2 4250.25 BRAKE PADS 1 4256.95 BRAKE PADS 8 4308.46 spring kit 1 4310.57 shoe aojust 1 4402.39 rl.h cylindr 1 4402.47 cylinder 1 4402.48 cylinder 4 4411.08 BRAKE SPRING 4 4427.37 CLIPS KIT 2 4427.47 brake kit 2 4427.47 1 4427.48 PAD KIT 2 4427.57 repair kit 2 4427.58 repair kit 2 4439.08 studs 2 4439.11 repair kit 10 4442.01 gasket 1 4448.34 repair kit 1 4449.15 4 4449.45 repair kit 2 4449.47 2 4534.09 CONTACTER STOP/MANO CONTACTS 2 4568.1 CHEEK 1 4575.09 T UNION 1 4575.11 UNION 1 4599.07 satz 1 4599.11 repair kit 1 4599.12 repair kit 1 4599.13 MANO CONTACTS 5 4599.21 MASTERVAC/REPAIRKIT 2 4599.23 MASTERVAC/REPAIRKIT 1 4601.98 maitre cylmore frein 1 4643.18 mano contact 8 4654.07 connector 4 4654.08 plug 1 4803.45 tuyan de frein 1 4806.21 2 4806.46 1 4806.48 1 4834.73 cable 2 4834.73 1 4890.04 1 5094.32 8 5096.02 2 5096.07 2 5164.16 rest 1 5904.47 1 5918.75 1 5918.85 1 5927.89 5 5933.32 2 5933.58 5 5933.6 1 5937.25 3 5937.28 1 5937.31 2 5937.34 2 5937.42 1 5940.13 2 5941.798 1 5979.78 harness PN 1 6122.38 1 6122.7 1 6122.74 1 6123.42 2 6123.43 1 6123.58 1 6203.43 rh hdlamp 1 6203.92 lh hdlamp 3 6221.17 5 6248.1 1 6301.59 feu av gauche 1 6301.6 feu av droit 1 6346.34 platine feu ar 1 6351.31 tail light 1 6433.69 union 1 6453.76 galet tendeur 2 6461.9 valve 1 6500.02 print circ 5 6540.76 connector 1 6552.54 plug 1 6552.86 switch 1 6553.72 1 6602.18 reducer 1 6602.24 motoreduc lev d 5 6941.6 1 7810.42 1 8121.06 1 8122.84 MIRROR 1 8122.86 1 8146.08 3 8214.5 SLEEVE 1 8227.42 2 8227.45 CIGAR LIGHTER 2 8227.46 CIGAR LIGHTER 4 8249.18 gasket 4 8427.32 UNION 3 8436.41 1 8535.33 MLDG STRIP 2 8616.11 SPRING 1 8622.14 KIT 1 8630.29 TRUNK LOCK 1 8654.13 STRIKER 8659.06 rear name 2 8660.21 STRIPE 2 8660.22 STRIPE 2 8664.04 WASHER 2 8717.16 1 8731.84 MOULDING 2 8941.95 1 9159.4 moulding 1 9221.68 2 9453.25 1 9606.64 1 9659.42 concealer 1 9682.72 foghte 405 1 9763.66 1 ############ 1 1250.C5 1 0002.42 frtendmsk4 2 0025.79 1 0036.11 install whon kit 1 0039.62 1 0039.63 mast sosson 1 0040.60 1 0089.11 latch gl box 1 0091.A8 tool J36876 1 0092.49 1 0092.51 1 0093.06 bracket sef 3 0097.33 bearing grease 2 0099.62 springs 1 0099.C5 single light 3 0112.78 6 0112.95 gasket 1 0112.A0 1 0113.40 bearing set 1 0113.43 1 0113.44 1 0113.83 1 0113.91 bearing set 1 0119.06 5 0119.12 12 0127.05 10 0127.10 gasket 2 0127.11 3 0127.12 spring 4 0127.17 6 0127.19 seal 6 0127.26 bearing se 1 0127.28 crankshaft 9 0131.08 ring 6 0131.19 post 6 0163.21 5 0163.9. threaded P 5 0164.27 7 0165.04 gasket 1 0197.J3 engine gasket 1 0197.K8 engine gasket 1 0197.K8 engine gasket 1 0197.k9 valve gasket 2 0197.L4 1 0199.06 gasket kit 5 0204.21 1 0204.24 1 0204.26 screw 2 0204.51 cylhd bolt 1 0204.54 cylhd bolt 1 0204.55 cylhd bolt 10 0205.14 washer 22 0205.14 1 0209.L3 4 0212.03 shoulder 8 0213.06 gasket 1 0220.61 4 0220.87 valve guide 2 0220.88 1 0220.88 1 0220.88 1 0235.04 claptet 10 0236.16 3 0236.21 joint d arbre 2 0236.25 lip seal 4 0242.12 contactor 1 0242.29 thermocontact 1 0242.33 2 0242.37 thermocontact 1 0242.48 thermocontactor 3 0242.49 contactor 1 0242.58 1 0242.59 elect box 8 0243.03 gasket 3 0243.14 fitting 1 0249.14 1 0249.14 3 0249.25 gasket 1 0249.43 valve cover 2 0249.48 gasket 1 0249.64 2 0249.66 cover gasket 2 0249.74 cover gasket 4 0250.25 column screw 2 0250.26 column screw 2 0252.50 sending un 4 0253.05 rubber spacer 2 0258.13 bouchon 2 0258.13 filler cap 1 0258.13 1 0258.18 bouchon 1 0258.18 3 0258.25 filler cap 2 0258.25 9 0258.26 1 0258.29 6 0258.35 gasket air 2 0258.37 1 0277.24 1 0301.40 oil pan 1 0304.24 1 0304.28 1 0304.34 gasket 2 0304.44 1 0304.50 gasket 9 0310.10 5 0313.02 gasket 2 0313.14 gasket 2 0313.23 1 0321.39 gasket 3 0321.59 gasket 1 0321.61 timing cover 3 0321.61 timing cover 2 0321.63 seal 1 0321.65 gasket 1 0321.69 4 0322.14 gasket 2 0322.22 gasket 4 0325.10 plug 4 0326.22 1 0340.71 1 0340.71 4 0348.18 gasket 6 0348.21 3 0348.43 joint 8 0348.61 gasket 2 0348.A0 4 0348.A2 gasket 1 0348.G4 8 0349.08 gasket 8 0349.70 1 0349.88 1 0349.88 joint 1 0349.94 joint 3 0349.94 joint 6 0349.A8 1 0349.C0 manifold 1 0349.E8 3 0361.59 bracket 2 0362.47 addit air 12 0365.06 oring 4 0365.10 hose 8 0374.02 gasket 1 0376.02 1 0378.02 pipe gasket 3 0380.01 gasket 1 0380.04 gasket 1 0380.06 6 0380.08 gasket 1 0381.02 connection 2 0381.03 union 1 0382.02 1 0512.10 washer 1 0514.11 oil seal 1 0514.11 1 0514.11 1 0514.20 seal 2 0514.35 oil seal 1 0515.82 pulley 1 0515.E9 1 0516.18 screw 1 0516.24 nut 4 0524.06 bushing 1 0524.10 2 0524.12 1 0524.12 1 0524.16 bushing 4 0526.03 1 0606.97 1 0606.E7 1 0606.H1 bearing 1 0626.86 2 0640.24 ring set 2 0640.24 ring set 1 0640.25 1 0762.79 1 0816.07 1 0816.32 1 0816.40 timing belt 1 0816.71 2 0818.18 1 0818.18 1 0818.18 tendeur 1 0829.12 1 0829.29 tension rod 4 0906.47 washer 4 0906.48 washer 4 0906.49 washer 4 0906.50 washer 4 0906.52 washer 4 0906.53 washer 4 0906.54 washer 4 0906.55 washer 4 0906.56 washer 4 0906.57 washer 4 0906.58 washer 4 0906.59 washer 4 0906.60 washer 4 0906.61 washer 4 0906.62 washer 4 0906.63 washer 4 0906.64 washer 4 0906.65 washer 4 0906.66 washer 4 0906.67 washer 4 0906.68 washer 4 0906.69 washer 4 0906.69 washer 4 0906.70 washer 4 0906.71 washer 4 0906.72 washer 4 0906.73 washer 4 0906.74 washer 4 0906.75 washer 4 0906.76 washer 4 0906.77 washer 4 0906.78 washer 4 0906.79 washer 4 0906.80 washer 4 0906.81 washer 4 0906.82 washer 4 0906.83 washer 4 0906.85 washer 4 0906.86 washer 4 0906.87 washer 4 0906.88 washer 4 0906.89 washer 4 0906.90 washer 4 0906.91 washer 4 0906.92 washer 4 0906.94 washer 4 0906.95 washer 4 0906.96 washer 4 0906.97 washer 4 0906.98 washer 4 0907.07 washer 4 0907.08 washer 4 0907.09 washer 4 0907.10 washer 4 0907.11 washer 4 0907.12 washer 4 0907.14 washer 4 0907.15 washer 4 0907.16 washer 4 0907.17 washer 4 0907.18 washer 4 0907.19 washer 4 0907.19 washer 1 0948.61 3 0948.61 16 0950.05 half cone 4 0956.14 2 0956.14 1 0956.28 2 0956.28 5 0956.28 knob 22 0956.28 4 1019.10 gasket 1 1019.11 5 1104.15 seal 1 1109.35 oil filter 32 1109.35 oil filter 1 1109.45 9 1109.45 oil filter 2 1109.48 oil filter 7 1109.48 oil filter 2 1109.59 oil filter 4 1109.78 oil filter 6 1109.87 oil filter 4 1109.N2 oil filter 9 1109.N2 oil filter 5 1120.05 draing kit 1 1120.05 oil change gaskets 2 1120.05 oil change gaskets 2 1131.08 contuelor 1 1131.10 manocontact 1 1131.14 thermocontact 1 1131.19 1 1131.26 1 1131.30 1 1131.40 1 1131.40 thermistance 1 1131.41 pressure s 7 1131.43 gasket 1 1131.48 4 1131.48 olprswitch 1 1131.52 1 1131.69 sending union 20 1166.02 gasket 5 1166.13 gasket 11 1166.21 oring 1 1171.53 1 1172.38 1 1172.65 1 1172.79 1 1172.79 1 1172.86 oip stick 4 1172.88 2 1172.99 engine oil 1 1180.11 1 1180.18 1 1180.18 2 1180.48 1 1180.49 1 1180.58 1 1186.02 1 1190.74 raccord vaphui 1 1190.74 pcv hose 2 1191.06 hose vaphui 1 1192.44 raccord (hose) 1 1192.45 hose 1 1192.46 hose vaphui 1 1192.63 1 1192.63 1 1192.64 hose 1 1192.64 1 1201.61 1 1201.61 1 1201.73 water pump 1 1201.76 1 1201.83 1 1201.85 3 1206.23 6 1206.36 gasket 5 1206.40 gasket 3 1206.72 gasket 1 1206.74 fitting 3 1206.76 5 1206.86 gasket 9 1206.A4 gasket 2 1208.09 o ring 3 1213.22 hose 3 1213.23 hose 3 1213.24 hose 1 1250.C5 1 1253.12 1 1253.15 1 1254.36 fan 1 1254.42 blower 3 1254.48 1 1254.50 fan 1 1254.51 fan 1 1254.52 engine fan 1 1259.11 hub cap 1 1259.15 hub 1 1259.21 2 1264.14 1 1264.17 1 1264.18 contactor 2 1264.18 thermocontact 2 1264.21 2 1264.22 temperature S 1 1264.23 temperat S 1 1264.23 2 1264.40 thermocontact 2 1264.45 2 1267.11 5 1267.13 18 1268.01 spring 6 1268.06 spring 1 1280.07 belt 1 1280.07 1 1280.07 1 1280.16 belt 2 1280.16 1 1281.13 roller 5 1303.35 3 1303.37 4 1303.42 bouchon 2 1303.69 2 1305.10 pad fill cap 3 1306.10 2 1306.19 drain plug 5 1306.21 bleeder 2 1306.24 contactor 1 1306.24 9 1306.29 2 1306.32 contactor 1 1306.41 housing 2 1306.42 level switch 1 1306.57 1 1306.66 3 1306.74 filler plu 3 1306.74 filler plug 2 1306.85 bouchon 1 1307.22 2 1307.66 hose 1 1307.J6 1 1307.J7 raccord 1 1307.J7 raccord 1 1307.J7 1 1307.K2 1 1307.K2 1 1307.K2 union 1 1307.T0 1 1307.T0 2 1317.14 hose 2 1317.17 hose 8 1327.02 rubb block 2 1336.88 water quil 5 1337.20 1 1337.40 thermostat 4 1337.41 thermostat 2 1337.47 3 1337.49 thermostat 2 1337.50 3 1337.53 thermostat 3 1337.59 thermos 80 4 1337.72 thermocontact 1 1338.01 thermocontact 2 1338.03 thermostat 1 1338.11 thermostat 2 1338.20 thermostat 4 1339.10 thermostat 6 1339.20 gasket 1 1339.41 6 1339.47 2 1339.53 gasket 2 1339.66 6 1339.79 1 1340.04 gasket 2 1340.08 8 1340.22 3 1340.30 1 1341.03 hose 2 1341.04 union 1 1341.15 1 1341.38 1 1341.38 1 1341.80 1 1343.40 2 1343.40 1 1343.49 2 1343.50 sleeve 1 1343.51 1 1343.53 1 1343.61 hose 1 1343.68 union 1 1343.68 1 1343.77 hose 1 1343.78 1 1343.85 1 1343.85 1 1343.85 2 1343.A2 1 1343.A3 1 1350.26 2 1350.27 2 1350.34 nozzle 1 1350.44 hose 3 1350.46 hose 1 1350.46 1 1350.64 1 1350.64 1 1350.65 union 1 1350.65 1 1350.65 1 1350.71 1 1350.72 fitting 1 1350.73 hose 1 1350.73 water hose 1 1350.86 hose 1 1350.86 hose 1 1350.86 1 1350.88 water hose 1 1350.88 water hose 1 1350.89 water hose 1 1350.93 hose 1 1350.93 hose 1 1351.04 hose 1 1351.23 1 1351.31 2 1351.53 1 1351.54 1 1351.59 2 1351.61 1 1351.65 1 1351.65 1 1351.A2 water outlet 1 1351.A2 6 1355.04 rubber cap 3 1355.08 1 1403.35 1 1424.E4 1 1424.K0 filter air 4 1444.F3 element filtre 1 1445.77 filt element 1 1445.94 1 1502.27 valve 2 1502.32 1 1503.56 fuel pipe 1 1504.59 2 1508.24 1 1508.67 bouchon 1 1508.67 3 1517.26 bracket 1 1517.40 volet 1 1517.40 volet 1 1527.29 fuel sender 2 1528.19 1 1528.19 gasket 3 1528.23 cover gask 2 1531.05 ring 2 1536.18 cradle 2 1536.18 1 1554.82 1 1560.17 1 1561.C1 fuel pipe 8 1562.40 gasket 9 1562.44 gasket 10 1562.45 gasket 10 1562.51 1 1562.54 gasket 3 1563.47 1 1563.98 bracket 1 1563.98 bracket 1 1564.94 1 1564.94 1 1567.12 filler 2 1567.13 petrol filter 1 1573.10 rubber hose 1 1573.19 1 1573.20 1 1573.20 1 1573.28 1 1573.56 hose 1 1573.73 fuel rubber 1 1573.76 1 1573.7C 5 1573.NZ 1 1573.X1 hose 1 1573.X1 2 1573.X2 2 1622.91 1 1623.30 1 1623.30 2 1623.30 coupling 1 1625.63 1 1628.58 sonde oxygen 2 1628.C2 switch 1 1628.FO electvalve 1 1628.L4 1 1629.86 1 1703.80 heater hose 1 1710.70 joint tugau AV 1 1710.70 10 1714.44 rubber stud 1 1721.76 10 1735.16 10 1756.05 plate 1 1798.45 exhaust kit 1 1798.75 1 1801.29 1 1807.25 pad 1 1807.25 1 1809.21 1 1843.70 1 1843.95 12 1906.02 oil filter 1 1906.08 fuel filter 2 1906.08 oil filter 1 1906.11 fuel filter 1 1906.11 fuel filter 1 1906.11 fuel filter 4 1906.11 oil filter 5 1908.02 packing 1 1910.24 water pump 1 1910.24 3 1911.39 lattete damorcage 3 1911.39 lut 9 1912.02 gasket 10 1912.06 gasket 1 1923.10 plug 2 1925.12 oring 5 1927.04 gasket 4 1927.17 oring 5 1957.08 oring 5 1957.16 union 1 1957.21 control unit 1 1957.21 raccoro doseur 5 1981.02 seal washer 8 1981.05 gasket 12 1981.09 2 1981.25 12 2002.06 screw 1 2041.42 bearing 2 2089.11 2 2097.09 hose 1 2099.13 necessaire 10 2106.06 gasket 1 2128.17 biellette 3 2128.17 biellette 5 2138.04 clip 4 2141.11 bushing 2 2175.15 plug 1 2175.20 bushing 2 2175.21 bushing 2 2203.09 gasket 5 2208.23 plug 1 2209.11 gasket 4 2209.25 gasket 4 2212.07 seal 2 2214.05 gasket 1 2214.09 5 2214.11 5 2214.11 gasket 1 2221.11 1 2221.11 drain plug 2 2257.12 2 2257.29 switch 2 2257.30 switch 2 2257.33 switch 2 2257.35 switch 7 2263.03 ring 2 2263.11 strainer 2 2263.14 crepiore 8 2263.19 1 2263.20 7 2264.12 o ring 3 2264.13 joint plate 1 2264.13 joint plate 2 2264.15 1 2266.11 guage 1 2266.11 tube 1 2279.28 gear box p 1 2280.26 tuyau bva 3 2283.04 4 2284.06 screw union 2 2284.13 union screw 3 2362.10 joint d arbre 3 2400.33 2 2400.33 lever selector 2 2400.47 2 2403.67 poignet 1 2403.74 vigrette 1 2403.75 vigrette 1 2403.78 poigrue 3 2406.29 gasket 1 2406.79 soufflet 11 2410.27 poussoir levter 6 2410.27 poussoir levier 2 2410.34 spring 1 2410.34 spring 7 2410.34 ressort de CDE 3 2410.39 1 2410.45 spring 2 2410.45 spring 9 2410.45 resort 2 2415.25 bague de palier 1 2435.56 gear select 1 2435.67 5 2436.32 bushing 5 2438.05 agrafe 1 2444.69 cable 1 2444.99 cable 1 2444.A5 cable 1 2444.A5 cable 1 2444.K8 3 2450.12 3 2450.42 rouchon superie 4 2450.45 bouchon 1 2452.22 2 2452.28 biellette passa 1 2452.30 biellette pass 3 2452.39 biellette passa 1 2452.41 barre passage 1 2452.41 gear shift 2 2454.52 biellette selec 2 2454.60 biellette selec 1 2454.61 biellette CDE 3 2454.61 biellette selec 1 2454.81 link assem 1 2454.81 biellette selze 1 2454.85 biellette seld 1 2454.85 biellette selec 1 2454.89 link assem 2 2454.A3 2 2454.A4 1 2454.A4 contru 4 2482.43 1 2592.12 hub 3 2636.03 2 2643.02 pinion 8 2645.09 oring 1 2645.12 gasket 2 2649.04 pinion 1 2649.20 speedo dri 2 2649.20 speedo DRI 3 2650.07 pin 1 2753.02 hose 1 2806.08 1 2829.06 dust boot 1 3010.13 oring 1 3012.03 1 3045.21 2 3062.06 pad 1 3121.13 jointpont 3 3121.44 joint a leure 4 3206.11 gasket 2 3206.20 seal 3 3206.21 support set 17 321.61 7 3252.04 screw 4 3254.02 nut 2 3255.03 1 3293.59 ens protection 1 3293.91 ens protection 4 3297.02 nutlog 2 3311.13 stud 13 3318.13 nut 1 3326.28 2 3326.34 2 3326.34 bearing 1 3326.35 wheel bearing 1 3326.37 bearing 1 3326.50 bearing 2 3334.31 bague d arbre 4 3345.26 ring 8 3345.30 4 3345.31 3 3345.35 ring 1 3346.06 seal ring 2 3350.17 bearing 2 3509.13 screw assy 2 3509.14 screw hrdl 1 3509.15 1 3509.15 protector 2 3509.23 subframe screw 4 3523.10 4 3523.10 5 3523.12 articulation 1 3523.12 3 3523.16 2 3523.89 articulation 1 3524.09 washer 2 3561.04 1 3561.04 1 3561.04 1 3561.10 2 3561.10 1 3640.13 3 3640.13 repair kit 1 3640.21 1 3640.21 rotate pivot au 1 3640.25 1 3640.25 1 3640.27 1 3701.42 1 3714.20 7 3714.20 vislcove screw 1 3724.09 3 3724.18 oil seal 1 3724.29 4 3724.29 oil seal 1 3730.15 bearing 3 3736.30 washer 3 3736.30 plain washer 2 3739.14 nut 2 3740.12 cap 2 3740.30 hub cap 4 3748.15 repair kit 2 3812.59 1 3812.65 1 3817.48 botler 1 3817.50 1 3817.50 rod ball 1 3817.50 1 3817.50 1 3997.14 transmission filter 1 400.64 brake cali 1 4003.25 1 4003.25 1 4003.65 belt 1 4003.65 1 4009.22 belt 1 4009.22 5 4018.42 clip 2 4020.17 lp hose 1 4020.21 tube 1 4020.22 hose 2 4020.34 tube 2 4020.42 hose 2 4020.60 LW PRSS FL 2 4020.78 Flexible HPASSG 1 4020.87 pipe 1 4020.B7 tuyau HP 1 4020.C4 Tuyau Basse Pre 1 4021.71 peugeot starter 3 4066.16 protector 3 4112.F8 contactor 2 4402.56 brake cylinder 1 4569.08 1 4569.12 belt 1 4569.12 1 4569.17 1 4569.17 1 4599.15 1 4806.47 1 4827.18 1 4834.00 2 5094.21 1 5094.32 8 5096.02 spacer 2 5096.07 bar spacer 1 5131.27 3 5131.48 roulement 4 5131.49 roulement 2 5151..06 nut 2 5152.40 support 1 5152.41 support 2 5152.53 support 5 5161.06 palier de barre 2 5164.15 pad 2 5164.28 appui ressor ap 2 5164.29 pad 2 5248.16 bushing 4 5249.29 2 5254.07 2 5254.07 5 5255.04 cup 2 5346.13 cap 2 5346.13 cap 2 5399.24 kit 2 5399.24 kit 1 5404.A7 6 5405.09 6 5405.09 5 5405.31 ecroo fix roue 5 5405.31 ecroo fix roue 4 5405.35 screw 4 5405.35 screw 8 5405.39 cover 8 5405.39 cover 1 5414.13 1 5414.13 1 5437.31 rotor 1 5615.21 clamp 1 5615.21 clamp 1 5625.07 1 5625.07 1 5703.19 screw 1 5703.19 screw 1 5703.24 screw 1 5703.24 screw 2 5703.35 screw column 2 5703.35 screw column 1 5749.11 1 5749.11 2 5749.11 1 5749.24 1 5749.24 2 5750.26 1 5750.26 1 5750.46 1 5750.54 belt 2 5750.54 1 5750.54 1 5750.60 1 5750.63 2 5750.63 1 5750.63 2 5750.70 belt 1 5750.70 1 5750.70 belt 1 5750.72 2 5750.84 belt 1 5752.02 bearing 1 5904.47 1 5904.A7 1 5918.75 1 5918.85 speed sensor 1 5927.89 5 5933.32 joint torique 2 5933.58 5 5933.60 1 5937.25 rotor 3 5937.28 rotor 2 5937.34 2 5937.42 rotor 1 5940.13 1 5940.39 2 5941.798 1 5962.22 spark plug 2 5962.A6 1 5962.H8 1 5967.B4 1 5967.L2 ignition it 50 6086.30 50 6086.38 50 6086.88 4 6112.18 bulbholder 2 6112.26 2 6112.26 13 6112.34 1 6122.34 1 6122.38 1 6122.70 cable 1 6122.74 cable 1 6122.74 cable 1 6122.82 2 6122.90 speedo cable 1 6123.08 stock exhau 1 6123.11 speed cable 1 6123.42 2 6123.43 trans flex 2 6123.57 speedo 1 6123.58 speedomet 1 6123.58 2 6123.60 1 6123.81 1 6123.81 2 6123.82 flexible c 1 6123.94 1 6123.A3 1 6123.A3 2 6155.78 3 6160.14 knob 6 6203.99 1 6203.A0 enjoliveur 1 6203.A1 1 6204.90 1 6205.88 clips kit 2 6205.90 1 6212.33 cuvelage 4 6215.22 harness 5 6215.26 1 6223.07 support 1 6223.21 brackets 1 6223.22 2 6223.23 breather 1 6223.24 breather 2 6225.59 nut 4 6225.60 bushing 1 6239.06 commutateur 5 6248.10 1 6253.38 switch 1 6253.38 switch 1 6253.39 switch 1 6253.39 switch 1 6253.40 bloc cde signa 1 6253.40 bloc cde signa 1 6301.59 feu au gauche 1 6301.93 1 6301.93 1 6301.93 1 6301.93 1 6301.96 front light 1 6301.96 front light 1 6301.97 front light 1 6301.97 front light 1 6301.98 clignotant 1 6301.99 flasher un 1 6323.24 flasher on 3 6340.60 light 2 6340.61 1 6346.34 platine feu ar 1 6346.34 platine feu ar 1 6346.35 printed CI 2 6346.63 bulbholder 1 6346.66 1 6346.67 bulbholder 2 6346.68 1 6346.68 1 6346.68 2 6357.40 light 1 6357.41 lights 2 6357.44 side light 1 6357.44 1 6357.45 5 6357.47 side light 2 6357.48 side light 2 6357.48 7 6359.21 lbulb holder 1 6359.22 protector 1 6362.34 plate lamp 1 6362.71 plajer ca 3 6362.92 intr light 2 6366.24 breaker 2 6371.09 bulb 1 6371.20 bulb 2w 20 6422.20 snap ring 2 6422.20 8 6422.21 snap ring 3 6422.25 plug 1 6422.26 1 6426.94 wiper 1 6431.20 reservoir 1 6432.25 cover 3 6432.30 comver 1 6433.69 union 1 6434.36 pump 1 6434.36 elct pump 2 6434.45 seal 2 6438.37 1 6438.37 1 6438.60 2 6438.60 4 6438.71 1 6441.G5 1 6444.89 1 6445.71 1 6445.72 rheo stut 1 6445.72 rheostat 1 6445.72 1 6445.84 module 1 6445.A2 1 6445.A3 1 6445.A6 1 6445.C2 4 6445.H4 2 6447.58 moto-reaucteur 1 6448.54 1 6451.30 control board 1 6451.30 mount plate 1 6451.53 control board 1 6453.60 switch 1 6453.E7 1 6453.L2 belt 1 6453.L2 belt 2 6453.L2 1 6453.Q5 filter dryer receiver 1 6453.Q5 reservoir 1 6455.04 belt 1 6455.39 spacer 1 6455.73 pres switch 2 6455.A1 union 1 6455.D4 1 6455.D4 1 6455.D4 1 6455.L1 Ohyo PRSS 1 6455.R9 1 6455.S deshydrat refri 1 6456.41 1 6456.46 roller 2 6456.69 5 6456.70 1 6456.72 2 6456.73 slide 1 6456.79 slide 1 6456.80 slide 1 6456.80 4 6456.82 tie rod 1 6457.53 1 6457.F9 1 6457.G7 3 6457.K4 plate 20 6457.R1 gasket 20 6457.R2 30 6457.R3 1 6458.32 1 6458.69 1 6458.69 1 6458.80 pipe 1 6459.54 hose 1 6459.54 hose 1 6459.55 1 6459.56 heating tube 1 6459.56 1 6459.58 tube 1 6459.60 inlet tube 1 6459.61 inlet tube 1 6459.61 hose 1 6459.64 hose 2 6461.60 valve 1 6461.64 detendeur 1 6461.64 1 6461.82 thermostat 8 6462.40 heater gasket 1 6464.73 1 6464.73 tube 1 6464.87 1 6464.96 1 6464.96 1 6464.97 1 6464.98 1 6464.98 2 6464.C5 2 6474.04 resistance 2 6476.33 knob 1 6493.21 1 6503.71 1 6503.71 cover 5 6524.03 diode 2 6538.30 protect S 6 6540.14 wirtermnl 20 6540.25 terminal 50 6540.28 5 6540.76 connector 10 6541.12 terminal 3 6541.60 18 6542.19 connector 10 6542.28 connector 2 6542.30 connector 1 6542.W9 elec clip 1 6543.1N harness 2 6543.3H 1 6543.50 1 6550.25 4 6550.37 rheostat 2 6550.48 contactor 5 6550.71 contactor 2 6550.95 actuator 1 6551.18 door lock 4 6551.20 obturator 2 6551.21 switch 1 6551.98 switch 1 6552.16 2 6552.46 plug 2 6552.47 plug 1 6552.54 1 6552.60 1 6552.60 3 6552.61 switch 2 6552.89 switch 1 6552.90 1 6552.90 1 6552.91 1 6552.91 switch 1 6552.92 1 6552.93 wiper switch 1 6552.F8 switch 1 6552.H5 switch 1 6552.H5 switch 5 6552.N8 2 6552.Q5 3 6553.08 2 6553.37 air switch 1 6553.48 1 6553.69 switch 1 6553.71 switch 1 6553.71 1 6553.72 1 6553.72 1 6553.72 2 6554.54 1 6555.22 relay 1 6555.23 1 6555.30 2 6555.33 3 6555.34 relay 2 6555.35 1 6555.36 relay 1 6555.45 1 6555.45 change our 1 6555.48 relay 1 6555.48 relay 3 6555.52 1 6555.54 control box 1 6555.57 3 6555.60 5 6555.65 relay 5 6555.88 relay 1 6555.F1 control box 3 6555.HL 1 6602.24 motoreduc lev d 1 6615.02 T6/ TRMOTOR 1 6615.02 1 6615.05 actuator 3 6651.09 relay 1 6660.38 electr box 2 6736.41 1 6736.41 tensioner 4 69.9.80 nut 10 6905.36 screw 6x12 10 6907.18 2 6913.46 screw 8x55 20 6913.48 5 6913.54 screw 5 6914.77 screw 4 6918.18 screw 2 6921.20 screw 4 6921.42 screw HM8XI 8 6929.06 stud 6 6929.15 stud 4 6929.17 8 6929.23 3 6929.43 stud 4 6932.06 nut H8 3 6935.50 nut 1 6939.10 nut 4 6939.34 12 6939.42 5 6939.67 nut 4 6941.60 nut 5 6941.60 6 6947.98 washer 2 6948.10 2 6948.10 9 6955.31 washer 10 6967.58 clip 10 6968.35 dowel 20 6972.06 5 6976.06 key 1 6979.85 snap ring 2 6981.36 clamp 3 6981.37 clamp 15 6982.A5 9 6982.A6 3 6982.A6 5 6986.05 hook 20 mm 200 6987.15 fitting 10 6987.20 nut 100 6991.37 clip 18 6991.83 clip 12 6992.64 support clamp 10 6992.95 retaining 10 6992.A3 clip 10 6992.C4 10 6992.E0 clip 10 6992.E1 clip 10 6992.E4 clip 10 6992.E9 10 6992.G1 clip 10 6992.G3 clip 1 6993.75 30 paknuts 1 6993.85 25 pack screw 1 6996.34 22 pack clip 10 6996.36 retain clip 2 6996.42 12 pack clip 2 6996.45 20 pack clip 1 7011.7G 1 7410.95 1 7452.19 bump joint 1 7452.22 1 7494.48 fastener 2 7587.N9 1 7587.N9 1 7804.77 support 1 7804.78 support 5 7813.07 o ring 2 7841.65 fender 1 7934.33 bonnet loc 1 7934.34 bonnet loc 2 7937.39 cable 1 7937.55 cable 1 7937.69 1 7937.69 1 7937.74 opening co 1 7937.78 lever 3 7953.07 pull rod 2 8094.09 1 8121.04 1 8121.05 1 8122.85 woscrn mou 20 8123.21 clip 3 8123.39 clip 10 8123.40 clip 6 8123.41 trim clip 11 8123.44 stock exha 33 8123.46 clip 5 8123.52 1 8146.08 1 8146.38 1 8148.C7 LOT FERMETURE 2 8149.87 adaptation 2 8149.87 adaptation 1 8155.24 rr vw mirr 1 8155.26 rr vw mirr 1 8155.26 rr vw mirr 2 8156.38 boot 2 8156.38 boot 1 8214.L5 snap ring 1 8214.S1 SRBEADCLIP 1 8220.84 1 8220.84 1 8220.84 lock plate 2 8221.37 2 8221.37 2 8222.32 limiter 2 8222.32 limiter 1 8230.57 4 8349.32 clip 1 8411.08 bracket 1 8411.09 bracket 1 8422.27 panel slid 1 8422.28 panel slid 1 8622.14 compensatr 1 8659.C2 nameplate 2 8659.H6 405 nameplate 1 8725.13 1 8725.14 1 8726.58 trunk lock 1 8728.05 spring 1 8728.06 finger 1 8728.15 lock control 1 8729.13 gasket 1 8731.83 compensatr 1 8731.83 2 8746.42 clip 2 8746.43 2 8746.44 clip 2 8746.45 clip 2 8941.96 junction 6 8957.E9 control bu 1 8971.30 bracket 4 8971.31 spring 3 8971.JY belt mechanism 2 8971.JZ belt mechanism 1 8978.79 strap & SE 10 8978.90 plain washer 1 8978.E7 hook 1 8978.E9 belt screw 2 8979.38 belt sldel 1 9015.67 gusset 1 9035.45 hinge 1 9035.46 hinge 1 9035.60 1 9037.27 1 9037.42 hinge lower 2 9041.05 countraplat 7 9044.16 hinge pin 5 9044.30 hinge pin 1 9045.08 clip 1 9045.09 10 9045.10 screw 1 9101.53 1 9101.80 handle 1 9101.88 1 9101.89 1 9102.27 handle 1 9120.98 moulding 1 9120.98 moulding 2 9140.09 1 9140.13 dr. guide 3 9141.13 lock control 1 9141.17 dr. guide 1 9143.30 int control 1 9143.30 int control 1 9143.47 1 9143.47 handle 1 9143.48 handle 1 9144.30 int control 20 9147.02 bearing 13 9147.04 plastic cl 6 9158.27 knob 3 9159.39 knob 2 9159.47 4 9159.50 knob 2 9159.52 3 9164.21 striker 2 9181.46 door arres 9 9181.63 pin 1 9203.32 window 1 9209.23 strip 1 9215.09 1 9215.10 fitting 1 9221.68 window lift 1 9221.68 window lift 1 9222. 1 9224.12 window lift 3 9227.18 guide 3 9227.20 clip 3 9227.21 fork bearing 1 9230.13 stop 1 9241.14 escutcheon 2 9313.04 clip 2 9313.07 clip 2 9453.25 1 9604.97 concealer 1 9605.39 hub cap 3 9605.39 hub cap 1 9605.39 1 9605.87 1 9605.87 1 9605.87 1 9605.87 4 9605.87 1 9606.64 1 9606.64 1 9606.64 1 9606.68 ecrou roue alu 1 9606.68 1 9606.68 2 9606.68 1 9606.E4 1 9606.E4 3 9616.80 roof bars 1 9617.21 2 9617.21 locks 1 9621.97 car plate 1 9646.17 steering wheel hub 1 9682.72 foglite 405 3 9716.31 base ring 3 9716.41 1 9716.43 1 9716.43 base ring 1 9716.44 2 9743.44 1 9743.61 1 9763.66 3 9926.05 key blank 8 9926.20 key blank 2 9926.32 key blank 2 9926.44 key 3 nameplates peugot, STI misc XN6 misc XU9J2 weight misc XU9J4 2 oil filter 3 manual antennae kit 2 2 water pumps 1 used instrument cluster 19 keys 1 manual antennae kit 405DL 94V0.64 fuel line eteriorahon door handle dip stick misc. seals misc. gaskets steering wheel hood struts misc. a/c hoses plug wires speedometer cables 2 new starters turn signal 2 new alternator filter electric seat belt tensioner antenna misc. hoses window truck head gaskets 4 used instrument cluster numerous body moldings 3 used cd players door panel door stop new starter 2 new brake discs 3 used headlight assemblies 2 used turn signals instrument stalks 404.395 12v window motor 8661.58 plate Sheet2 Sheet3 Quote Link to comment Share on other sites More sharing options...
Vjeko Posted October 29, 2015 Report Share Posted October 29, 2015 And where ended this parts? I need 8659.77 antenna plastic elipsoide base of telescope exit on rear right fender for Peugeot 505 models '89 on. Quote Link to comment Share on other sites More sharing options...
andrethx Posted October 29, 2015 Report Share Posted October 29, 2015 dude, the original post was from 8 years ago, i'm sure this stuff is long gone. you need the 89+ antenna base gasket -- i haven't seen them sold individually in forever, but jessie at dubarr (huntington beach, CA) offers the antenna/gasket combo kit from time to time on ebay. IIRC they go for around US$89 + shipping. maybe more than you wanted to spend but you'd get a new antenna as well. you could call him to see what he has on hand... andré Quote Link to comment Share on other sites More sharing options...
Vjeko Posted October 29, 2015 Report Share Posted October 29, 2015 I know it is over 8 years old but still maybe this part is in some warehouse waiting. Thanks for info. Quote Link to comment Share on other sites More sharing options...
