trymes Posted August 29, 2017 Report Share Posted August 29, 2017 As part of the saga of sorting out issues with my newly acquired Gas Turbo car, I spoke with Brian Holm to source a new Accordion tube to connect the air filter and the turbo inlet. While he did not have the right part for a gasoline-powered car, he suggested that I could modify the part from a diesel to fit. After getting the part, I was easily able to drill out the blank boss where the inlet from the charcoal canister connects and transfer the nipple to which it connects. Unfortunately, after having put the part in the car, it appears to me that perhaps it is rotated differently? If I rotate the accordion such that it most easily fits (with the least twisting and turning), the hose from the valve cover does not reach. If I rotate it such that the hose from the valve cover reaches, I have to contort the accordion in such a way that it seems wrong to me, and perhaps likely to shorten its life. Of course, I can just extend the hose from the valve cover breather, but I thought I would ask here if anyone knows whether the Diesel and Gasoline turbo accordion tubes differ in any way, other than the omission of the charcoal canister connection on the Diesel part. Tom Quote Link to comment Share on other sites More sharing options...
Bean Posted September 5, 2017 Report Share Posted September 5, 2017 I've noticed they looked similar - but I've never compared them side by side. Is it working OK for you now? Rabin Quote Link to comment Share on other sites More sharing options...
trymes Posted September 5, 2017 Author Report Share Posted September 5, 2017 It is working well, but I need to modify the breather hoses so I can adjust the accordion to a more natural bend. If I leave it the way it is currently installed, I'm worried it will shorten its lifespan (not drastically, but still). Quote Link to comment Share on other sites More sharing options...
