ComfortEagle Posted March 29, 2016 Report Share Posted March 29, 2016 Looking for some information. I would like to put power steering on my 504. Not even sure if they came with power steering. It is a really clean 1974 with only 88k. Quote Link to comment Share on other sites More sharing options...
SRDT Posted March 29, 2016 Report Share Posted March 29, 2016 They ended production in 2005 so yes some came with power steering, and even back in the day. You should also take a look at 604 and 505 steering racks as these cars are pretty close in a lot of aspects. Using an electric pump can be a good solution if you can't source the correct pump an bracket for your engine ; also using an electric setup adapted to the steering column may be the easy path as you don't need to hunt for old Peugeot parts at all. Quote Link to comment Share on other sites More sharing options...
Bean Posted April 16, 2016 Report Share Posted April 16, 2016 Sorry - didn't see this posted! Welcome to the forums ComfortEagle. 504 definitely came with powersteering, but the easiest way to do it would be to use the set up off a 505 diesel. The inner tie rods will be too long, but it should be possible to modify. A power 504 rack is harder to come by - but checking venders Brian Holm in Vermont or Ukit in California might be able to get you set up. Rabin Quote Link to comment Share on other sites More sharing options...
