themcguire Posted August 4, 2013 Report Share Posted August 4, 2013 Hello. I just learned how to do a/c recharge on my other vehicle and want to redo my 505. However I cannot find the "High" port. This car was converted to R134a some time ago and now the a/c is not working well. I want to start from scratch because I suspect that the shop that converted it did not do a proper flush before conversion. But. I cannot find the high port. It's not in my Haynes manual and I have traced the system multiple times and still cannot find it. Does anyone know about 505 a/c systems that can give me clue where to find the high pressure port ? Quote Link to comment Share on other sites More sharing options...
Bean Posted August 4, 2013 Report Share Posted August 4, 2013 I can't help with the location, but I can point you to the Peugeot-L yahoo group where there are a couple of techs that should be able to help you out if no one else knows for sure... http://autos.groups.yahoo.com/group/Peugeot-L/ Quote Link to comment Share on other sites More sharing options...
JunktionFET Posted August 5, 2013 Report Share Posted August 5, 2013 If you have the XN6 (2.0 liter non-turbo 4 cylinder gas engine), the high side port is normally in one of two places. It will either be attached to the Receiver Drier or will be next to the Expansion Valve near the firewall. On pre-'85 XN6 cars, they were always the latter--at the Expansion Valve near the firewall. Starting some time in 1985, Peugeot started installing a high pressure switch that screwed into the port, thus eliminating a dedicated port. Such cars may nor may not have a dedicated port at the Receiver Drier, in which case, you'd need to unscrew the pressure switch and connect the high side manifold gauge there. Quote Link to comment Share on other sites More sharing options...
