august Posted February 25, 2007 Report Share Posted February 25, 2007 does anyone know if the 505 turbo alternator is interchangeable with any other cars? I'm looking for a new valeo alternator (non-rebuilt), but i'm really not looking forward to the "peugeot premium". also, does anyone know the valeo part number for the 505 turbo unit? or know where i might be able to find one cheap? ($330 from western hemispheres, ouch!) any info would be appreciated. UPDATE: part numbers: Lucas A1274 Paris-Rhone A14N59 Paris-Rhone A14N88 Peugeot 570512 Peugeot 570566 Valeo 432806 Valeo 436320 PFI A-PR14894 ...basic info: Description: 12V, CW ROTATION, 80 AMP, Internal Regulator Quote Link to comment Share on other sites More sharing options...
N9TE Posted February 25, 2007 Report Share Posted February 25, 2007 I went down that road. Not fun. No real interchangeability I came across. Realistically, if you had to, you could make nearly any alternator work. The tricky part would be mechanical - ie: correct fitment. However, there's a much easier route and you get to keep you stock Valeo. Have it rebuilt. I had mine rebuilt and it worked fine for 6 months and then took a poo. Turns out the jobber brushes wore down in that time. I must've put a whole 3,000 miles on it. Anyway, I happened to have in my stash a new Peugeot brush/regulator assembly and once that went in, it was fine. The charge indicator in the dash still ever so faintly glows when idling with lights on and I hit the brake pedal, but so far, I'm keeping the battery charged as intended. Other rebuildables required for an alternator R&R are readily available to rebuild shops - bearings, etc. The only thing that will really cause you grief is the armature or stator. Those things nearly never wear out. If you're going to tackle the alternator job, do yourself a favor and tackle the power steering issue(s). At least the part where the PS resevoir douches the alternator. Cost to me was $100. The correct regulator/brush assembly for my car (87 S - N9TE/5sp, alternator Valeo A14N88) is a Paris-Rhone unit (pn: 5761.67). W-H has them for $97. Quote Link to comment Share on other sites More sharing options...
august Posted March 20, 2007 Author Report Share Posted March 20, 2007 update: i decided to go with a reman bosch alternator from napaonline.com. It showed up today, only to find that it's not going to work so note to anyone out there: NAPA Part# BSHAL329X will not work on a 505 turbo!!! Quote Link to comment Share on other sites More sharing options...
