Ruben Enriquez Posted March 4, 2014 Report Share Posted March 4, 2014 Hi please help how can I lift up the rear suspension of the car so the tires wear evenly? Do all peugeots get this problem? The rear pasenger tire is the most lowered. they wear out on the inside.THANKS Quote Link to comment Share on other sites More sharing options...
Bean Posted March 5, 2014 Report Share Posted March 5, 2014 If the rear end is sagging then your rear springs will need to get replaced. If the ride height is OK, then the rubber bushings in the rear crossmember may need replacing, or I have heard that the rear cross member may be sagged or bent. More details and ideally pictures of how the car sits on level ground would help. Rabin Quote Link to comment Share on other sites More sharing options...
bill Posted March 5, 2014 Report Share Posted March 5, 2014 I just had my 86 turbo sedan aligned along with new Michelins, and the guy said that the rear springs are sagging a bit, so you'll probably see some inside wear. He said to rotate the tires periodically at 6000 miles. Bill Quote Link to comment Share on other sites More sharing options...
