2pac Posted February 4, 2013 Report Share Posted February 4, 2013 hello is it possible to install a double barrel carburetor from newer models without changing the cylinder head? thx Quote Link to comment Share on other sites More sharing options...
Bean Posted February 7, 2013 Report Share Posted February 7, 2013 There is a stock intake manifold that has the single port at the head and the 2bbl Weber / Solex carb mount, and if I recall properly it was off the '71 504. I have an XN1 out of a 1980 505 SR and it has a two port intake with the 2bbl car which I replaced with a 32/36 Weber and it's fantastic. Are you in North America? Other countries have more options, but it's pretty limited here. I've never seen the XM7 motor - what does the current carb set up look like? Rabin Quote Link to comment Share on other sites More sharing options...
2pac Posted February 7, 2013 Author Report Share Posted February 7, 2013 in the xm7 the head has one port for the intake manifold. Quote Link to comment Share on other sites More sharing options...
Bean Posted February 7, 2013 Report Share Posted February 7, 2013 I think Russ did what you are wanting to do: http://www.aussiefrogs.com/forum/showthread.php?t=95889 If the head has the same port set up as Russ' 504 then what he did should show exactly what is entailed. Rabin Quote Link to comment Share on other sites More sharing options...
