JunktionFET Posted May 16, 2012 Report Share Posted May 16, 2012 Does anyone know with absolute certainty whether or not the vented rotors from say, a 1985 505 Turbo, will clear the calipers on a car with solid rotors such as 1985 505 STI? I suppose another way of asking this is: Do the 1985 505s all share the same front calipers? This would of course imply the ATE version (as the Bendix version wasn't around in 1985). Quote Link to comment Share on other sites More sharing options...
Bean Posted May 17, 2012 Report Share Posted May 17, 2012 For certain: You can swap the turbo hubs, rotors, and the caliper assembly to the spindle and it's all plug'n play. (I'm doing this on my wagon) Not possible: If you just want to put the vented disk on the existing hub and use the existing caliper it won't work. The actual brake piston assembly is the same - but the caliper bracket is different to allow the greater thickness of the disk. Not sure: The wheel stud flange is thicker on the turbo cars, which will space the wheel out a little further. Now I've never tried to fit a vented disk to a non-vented hub with the thinner wheel stud flange - so it *might* work - but I'm not sure. The newer ABS flat spoke alloys have more clearance - so it might work with those wheels - but I'm just guessing. Hopefully that answers your question. Rabin Quote Link to comment Share on other sites More sharing options...
JunktionFET Posted May 17, 2012 Author Report Share Posted May 17, 2012 Thank you sir! Quote Link to comment Share on other sites More sharing options...
