Bean Posted June 26, 2009 Report Share Posted June 26, 2009 Hi guys, I was looking having my injectors cleaned in my quest to revive my 85' 505 turbo so I checked and the 255 injectors are much smaller than the 86' 505 turbos... The 802's flow ~300 cc/min Trouble is the 85' is a high impedance injector and Iassume no resistor pack. If I run the 86' injectors is there any advise for wiring up a resistance pack? Hoping someone is already familiar with the process and can advise - otherwise I'll have to figure it out and I was hoping it would be an easy upgrade... Rabin Quote Link to comment Share on other sites More sharing options...
V-M Posted June 27, 2009 Report Share Posted June 27, 2009 You can replace low ohm with high ohm without modifications, but otherway around u need resistor pack. It's 8ohm/inj what have to be added if needed. V-M Quote Link to comment Share on other sites More sharing options...
Bean Posted July 3, 2009 Author Report Share Posted July 3, 2009 After evaluating all the work to try and figure out what's wrong with the stock system - I decided to spend that time on the same ECU swap to the turbo Dodge ECU... It was my original plan - but then I hesitated and thought it might be better to get it running with the stock system first.... To many unknowns to get the stock system going though - so may as well attempt the Turbo Dodge set up... I'll be verifying the engine is OK with a compression test, and if that goes well I'll swap on my rebuilt water cooled T3 and the valve cover an TMIC stuff from the 86 while I fit the SMEC ECU... That's the plan anyway... Rabin Quote Link to comment Share on other sites More sharing options...
Johnny Posted July 6, 2009 Report Share Posted July 6, 2009 You already have the SMEC ECU and everything you need? I say go for it! Quote Link to comment Share on other sites More sharing options...
Bean Posted July 6, 2009 Author Report Share Posted July 6, 2009 Yup - I should have everything I need for the SMEC ecu - but I'm thinking I should get new sensors just to make sure the install goes well. I also have a good friend that's really into the Turbo Dodges - his Lancer (large 4 door car) with a 2.5T ran a 12.7 quarter mile time recently. Rabin Quote Link to comment Share on other sites More sharing options...
