Palme
http://
Stockholm, Sweden
Palme's Achievements
Välkommen! Great with one more member from Sweden. The speech synthesizer unit is located in a carpet "bag" under the passenger seat. Regarding the trouble shooting I have no advise at this moment, but hopefully you will sort at least something out now that you know where it's located. I have a 1988 N9TEA too. I had a look at both the kick panel speakers and the main unit when I did some job on the interior a couple of years ago, but I can't remember anything about wiring and such. And taking pictures for future use was of course beyond my intelligence ... But anyway, feel free to ask if you come up with any further questions about wiring etc., and I'll try to answer as far as possible. Actually, there was around 100 of them sold in Sweden 1988, but only about 46 of them are still in the register (i.e. not scrapped). Regards, Alex
'91 N9TEA Bad Cold Running and Idle
Palme replied to billbranch's topic in Peugeot 50x Series discussion
Allright, sounds good. Let's hope It will get better. By the way, now I noticed that year and engine was of course typed in the topic. Careless by me. Regards, Alex -
The readings for the NTC sensor should be: 8,200-11,000 Ohms at -10°C 2,280-2,720 Ohms at 20°C 290-370 Ohms at 80°C All data from: Technical training - System diagnosis ...So your readings are nothing but crap, I dare to say. They are ridiculously, almost impossibly low? It's a -91 N9TEA you have, right? And the NTC sensor is black? The black NTC sensor is grounded through the threads, and not through one of the connections on the sensor. Therefore the resistance should be measured between one of the connections and ground to get it right. Regards, Alex -
Great to hear, and that list is practically what I've been looking for for ages! Regards, Alex
Yes, I agree with you. It would be far more likely they used a complete sensor unit, but I just don't know how to investigate further. As mentioned, the "Ford-guys" didn't recognize it as a Ford part at all. I've checked other Peugeot-models (405, 605) and Porsches too, but they all use Bosch systems. My only theory is that everything that somewhat easy could be used of consisting components (control units, all kinds of wires, etc.) was, and then they just had had to make an "own" sensor head to make it fit to the wheel spindle. I mean, somewhere in the chain of parts you must modify a link to make Ford (/Ate) ABS-parts and Peugeot car-parts come together. Perhaps the sensor head was the easiest and most profitable to "modify"? Regards, Alex
Minor supplement ... Recently I replaced one of my front ABS-sensors. And on the connector I noticed a very small Ford-symbol. Remembering this thread I thought I'd do some research on these sensors, and see if they were sitting on the mentioned Ford Scorpios/Sierras as well. So I contacted a Ford spare parts-dealer who I knew had been into these things for a long time and surely knew old Ford parts. Unfortunately, he didn't recognize it as a Ford part. He thought that it was only the connector that Peugeot (/Ate) had gotten from Ford, and then used it with an other sensor head. To sum up: Front ABS-sensors from Ford are at least not interchangeable. Regards, Alex
I'd say that bead blasting is the solution. I've seen some bead blasted heads, and they practically looked like new. Regards, Alex
I got one of those adaptors domestically from my spare parts-contact. But thanks anyway, V-M! I got it mounted today, and now it all works just fine. Regards, Alex
Sorry, maybe I was a bit unclear. When I said "...and goes straight into the block", I should have said cylinder block, of course. And when I spoke about the "block" I meant what you call adaptor. Anyway, it's a -88 N9TEA (forgot to mention it, sorry), so I need one of those adaptors, then. If you V-M could think of selling the adaptor and sensor to across the sea, it would be great. But first I'll check with my usual spare-parts contacts, since it would be easiest getting one domestically. If I don't get one, I'll contact you. All right? Regards, Alex Palmqvist
Hmm... I got a bit confused when you mentioned a "block". I had seen the oil pressure sending unit, but nothing to be mentioned as a block. So I googled for some pictures, and found this: ...on this page. And there it is, the "block"! My pressure sending unit is all alone, and goes straight into the block. Then I'll just have to get one of those blocks, and a temperature sending unit. Regards, Alex
Hello everyone! My oil temperature gauge doesn't work (but the oil level indicator works, which as you know is in the same unit). So I've searched practically every square inch of the engine for the sending unit, but I just can't find it. My question is: Where is it? Or does it perhaps use the same sending unit as for the level indicator? But then the wiring confuses me ... Anyone who knows? Regards, Alex Palmqvist
Here it is... http://www.505turbo.com/forum/index.php?ac...post&id=878 Found it in this thread... http://www.505turbo.com/forum/index.php?sh...7&hl=poster I remembered seeing it some year ago, and a couple of months ago I decided to find it again. So, I searched my ass off, and finally found it ... But, it would be really nice if anyone knew if there's one with a higher resolution available somewhere, so that you could get a nice print out of it. Great ad. They sure knew how to make them in the 80's. Regards, Alex
Tack! That wasn't too bad. Perhaps it will be a set of adaptors when the time for new rims is here ... Thanks again! Regards, Alex
Thanks, but one more real close-up picture in "between" the spokes would be just perfect! Regards, Alex
Nice! As mentioned before, the offset looks perfect! I have too had some thoughts on a set of adaptors like those, but depending on wheels I'm a bit concerned that it could look a bit strange if you see too much of the adaptors. Therefore I would really appreciate if you could take a close-up picture of the hub/adaptor with the wheel mounted? Do you follow? Regards, Alex
