Guest Posted February 17, 2007 Report Share Posted February 17, 2007 My 1984 505S 105K diesel developed a power steering fluid leak during a couple weeks of cold weather last December 06. Temp only went down to low 20's F. but it was enough. The leak is on the right side (L/H drive US car) and it is leaking out of the rack and pinion seal, not out of the hydraulic ram as I expected. I have a full set of manuals, but they don't give any break down of the steering unit, just the removal. I have a couple questions: first, should there be steering fluid in the rack & pinion? Second, instruction on disassembly of the unit and replacement of the seal. Also, are seals available? The bellows is also shot and probably caused the failure in the first place- dirt and grime on the seal. I have removed the entire assembly, cleaned and I am ready to began the repair. Thank you Quote Link to comment Share on other sites More sharing options...
Guest Posted March 11, 2007 Report Share Posted March 11, 2007 Fogured out what was wrong, got the parts and fixed the problem. Quote Link to comment Share on other sites More sharing options...
N9TE Posted March 11, 2007 Report Share Posted March 11, 2007 So what was the exact problem and your brisk fix my fine neighbor to the south? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 14, 2007 Report Share Posted March 14, 2007 So what was the exact problem and your brisk fix my fine neighbor to the south? N9TE, The problem was a leaking lower seal in the steering valve body. It leaked into the rack & pinion and ran out the R/H steering arm. Had the boot been in tact I would not have been aware of the leak except for a continued loss of hydraulic fluid. I got my kit which has a bunch of seals and snap-rings that are not used from this site. http://WesternHemispheres.com The fix is easy. Quote Link to comment Share on other sites More sharing options...
