Hello Group,
having a problem with the warning lights in the dashboard that are always on, but there is no problem with the water temperature or the oil pressure,. This happened after charging the air conditioner with gas. Do not know what maybe causing the problem ???
Mechanics here can not find the problem
Welcome Armando,
A picture would help as you don’t specify which warning lights.  Normally any warning light is because the sensor connects to ground when it reaches its set point, so the wiring could be grounding somehow.
There are grounding trees on either side of the radiator, and 505’s are notoriously bad for poor grounds that can often cause all sorts of gremlins if other circuits find ground incorrectly.
