billbranch Posted January 4, 2015 Report Share Posted January 4, 2015 Last year someone I know replaced the factory line with a nice long piece of hydraulic/fuel line, long enough to run behind the vertical brake master cylinder to mitigate the bend to the fitting, long enough to reach to the back of the booster body itself, yes, right below the wiper motor assembly and the horizontal link with the sharp edge which moves in a saw-like motion when the wipers are operating. I never thought about it either when I changed the hose this year and attributed it to fraying on the bulkhead. Someone hadn't re-seated the grommet either. Last week the CHECK ENGINE light began lighting at stops. I said WTF and it must be the O2 sensor. Last week in a foggy rainstorm I needed to stop and the brakes did not work. I figured it must have been wet brakes.No I hit the guy's house because the brakes did not work. There was no vacuum to the booster. In the heavy rainstorm with constant wiper use I had sawn right through the hose. I fixed the problem today and what a relief: I used a $1.29 right angle black nylon union and jerry-rigged the whole affair and now all I need is a little body work. Happy New Year to All! Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted January 4, 2015 Report Share Posted January 4, 2015 I end up needing longer booster hose for my DSMlink MI16 project so I just got one at local hose store. It was $36 for 5 feet. Quote Link to comment Share on other sites More sharing options...
billbranch Posted January 5, 2015 Author Report Share Posted January 5, 2015 Savo, It is not the hose itself; it is the routing. DO NOT run the hose behind the master cylinder/on the cabin side of the master cylinder.If you must, watch wiper linkage in operation and see why the hose does not belong back there. I learned the hard way. Quote Link to comment Share on other sites More sharing options...
my3AWDgst Posted January 5, 2015 Report Share Posted January 5, 2015 It's in the same location as original. In my case it needed to be longer because intake manifold has change so fitting is on the bottom of intake manifold now. Quote Link to comment Share on other sites More sharing options...
