boostin'euro89 Posted April 4, 2006 Report Share Posted April 4, 2006 does anybody have a wiring diagram for the 505 N9TEA ECU? my apexi turbo timer is asking for an 02 sensor signal, the ground wire from the ecu and also Ignition 1 output and Ignition 2 output and a also a constant 12v signal there is also the optional hand brake signal wire which I think would be convenient I need to have this running asap because the my dash needs to be put back together this timer gives the option of being able to see an A/F reading, voltage and a countdown timer Quote Link to comment Share on other sites More sharing options...
august Posted April 4, 2006 Report Share Posted April 4, 2006 does anybody have a wiring diagram for the 505 N9TEA ECU? my apexi turbo timer is asking for an 02 sensor signal, the ground wire from the ecu and also Ignition 1 output and Ignition 2 output and a also a constant 12v signal there is also the optional hand brake signal wire which I think would be convenient I need to have this running asap because the my dash needs to be put back together this timer gives the option of being able to see an A/F reading, voltage and a countdown timer hmm, i'll have a look when i get home tonight.. turbo timer eh? what model did you get? Quote Link to comment Share on other sites More sharing options...
boostin'euro89 Posted April 5, 2006 Author Report Share Posted April 5, 2006 hmm, i'll have a look when i get home tonight.. turbo timer eh? what model did you get? I cant seem to find an actual part number but I found the exact one on the web http://www.apexi-usa.com/product_electroni...d=198&pageNum=1 Quote Link to comment Share on other sites More sharing options...
boostin'euro89 Posted April 7, 2006 Author Report Share Posted April 7, 2006 hey august any luck with the wiring info? i have removed the whole climate control/change holder piece for modifaction i'm too eager to get everything back together Quote Link to comment Share on other sites More sharing options...
august Posted April 11, 2006 Report Share Posted April 11, 2006 yeah i had a quick look.. the lamda signal is pin 20, and a 'ecu ground' you can find at pin 5 & 13. (both things mentioned above you'll find on the injection ECU, which is underneath the passenger floorboard. not sure what they mean by ignition outputs. and i'm honestly not sure if the 505 has a handbrake switch (wouldn't be too hard to find out though ) Quote Link to comment Share on other sites More sharing options...
