MrPeugeot Posted February 19, 2006 Report Share Posted February 19, 2006 Hello, Now that I once again have a working turbo in my car, I am determined to have a working turbo gauge. The gauge itself in the dash works, but it was receiving no signal from the sending unit. To that end, I replaced the vacuum line between the intake manifold and the boost gauge sending unit. Gauge still didn't work. On eBay last week, someone was selling a NOS boost gauge sending unit -- but for an '88-up 505 Turbo (Peugeot part # 1628.A5 -- see the attached pic). I figured...worth a try. I put it in today, and the gauge now responds to boost. However, it will only go between the first white line and the second white line...not even a quarter of the way up the scale on the gauge. (At this point, I'll mention that I have connected a calibrated auxiliary turbo gauge to make sure that the wastegate was working properly and that I wasn't overboosting. However, I want to have a stock look to the dash, and just want to make sure the factory gauge is in the right neighborhood). I noticed on the boost gauge sending unit that there is a screw on the front, right by the connection for the vacuum line. Is this for calibration? If so, will I be able to calibrate this to work correctly with my car, or is there a big enough difference in the boost gauge senders for the N9TE vs. N9TEA that it just won't work? Thanks, Adam '87 505 Turbo S 5-speed Quote Link to comment Share on other sites More sharing options...
august Posted February 19, 2006 Report Share Posted February 19, 2006 just posted this on peugeot-l i *think* the senders on the N9T, N9TE, and N9TEA are all the same. the adjustment you are talking about can adjust the calibration. if i remember right, screwing it IN will decrease the sensitivity. how much boost is your calibrated gauge showing? have you tried another tach / boost gauge? Quote Link to comment Share on other sites More sharing options...
MrPeugeot Posted February 19, 2006 Author Report Share Posted February 19, 2006 I am showing approx. 10psi on full boost. how much boost is your calibrated gauge showing? have you tried another tach / boost gauge? Quote Link to comment Share on other sites More sharing options...
