Freddedw Posted August 31, 2012 Report Share Posted August 31, 2012 i replaced my cylinderhead and of course i didnt get the distributor in the correct place. On what mark on the cylinderblock shall i set the timing? it runs pretty good now and the knock diod in the instrument cluster isnt flashing anymore;) but i want to be shure. Quote Link to comment Share on other sites More sharing options...
Bean Posted August 31, 2012 Report Share Posted August 31, 2012 Best way is to bring the #1 piston to TDC on the compression stroke, then align the distributor so that the rotor is pointing to the #1 piston, then time your car so that it's the 10 degree mark which is basically between the 12 and 8 degree lines. Rabin Quote Link to comment Share on other sites More sharing options...
Freddedw Posted August 31, 2012 Author Report Share Posted August 31, 2012 Thanks! i havent cleaned it properly, last time i looked i could only see lines. I timed it on i guess the second or third line on the left side on TDC line. Is there also figures so i can se "10"? Quote Link to comment Share on other sites More sharing options...
Bean Posted August 31, 2012 Report Share Posted August 31, 2012 There is a line in between the 12 and 8 marks - it's just not labelled. I just checked my timing when diagnosing my car so it's fresh in my mind. Pretty sure it's 12 - 8 - 4 - 0 - 4 - 8 on the scale with lines for the numbers and the dashes. Rabin Quote Link to comment Share on other sites More sharing options...
