Johnny Posted May 19, 2009 Report Share Posted May 19, 2009 I was thinking maybe you could take the waterpump apart and change bearings and seals in it. But how do you get it apart? Do I have to remove the pump wheel from the axle to get it apart? Quote Link to comment Share on other sites More sharing options...
Bean Posted May 19, 2009 Report Share Posted May 19, 2009 If I were to guess - you'd need to remove the pulley and push the shaft with the impeller out the back side. Once out hopefully you would have access to the bearings and seals. No idea though as it was easier to just by a replacement the last time I did it. Rabin Quote Link to comment Share on other sites More sharing options...
V-M Posted May 19, 2009 Report Share Posted May 19, 2009 Have u find replacement bearings for it? Where? V-M Quote Link to comment Share on other sites More sharing options...
Johnny Posted May 19, 2009 Author Report Share Posted May 19, 2009 No I haven't found replacement bearings, I'll go hunt for those when I get the waterpump open so I can see part # and take measurements. Quote Link to comment Share on other sites More sharing options...
V-M Posted May 20, 2009 Report Share Posted May 20, 2009 Well... u fill find some supricing bearing model from there :-D V-M Quote Link to comment Share on other sites More sharing options...
Johnny Posted May 20, 2009 Author Report Share Posted May 20, 2009 You know how to get them open? Is it like Rabin said? Quote Link to comment Share on other sites More sharing options...
Bean Posted May 20, 2009 Report Share Posted May 20, 2009 I was just guessing - so confirmation on disassembly would be great. As for bearings - as long as you can match the ID of the bearing to suit the shaft, a bearing with a bit larger OD means you just machine the housing to suite it. Same thing with the seal if that's the case. I did exactly that when working on a 1930's gas powered welder with a leaking water pump. New bearings and seal and it just took a little machining to get it to work very nicely. Rabin Quote Link to comment Share on other sites More sharing options...
V-M Posted May 20, 2009 Report Share Posted May 20, 2009 http://br.adroo.com/adpics/2009/04/49e73bb...d9c6470bc3f.jpg Quote Link to comment Share on other sites More sharing options...
