august Posted October 18, 2005 Report Share Posted October 18, 2005 JunktionFET mentioned something about a SV24 605, so i had to do a little research.. it isn't easy finding info.. if you have pictures, or any other data please add! car looks so damn cool! its got to sound amazing with exhaust. DimensionsWheelbase: 2800 mm 110.23 inTrack front: 1530 mm 60.23 inTrack rear: 1530 mm 60.23 inLength: 4722 mm 185.90 inWidth: 1800 mm 70.86 inGround clearance: 100 mm 3.93 inKerb weight: 1459 kg 3216.54 lbFuel capacity: 80 l 21.13 US galEngineCode: ZPJ 4Manufacturer: PeugeotType: V-6in 90° veeSOHC24 valves total4 valves per cylinderMain bearings: 4Bore x stroke: 93.00mm × 73.00mmBore / stroke ratio: 1.27Displacement: 2975 cc 181.54 cu inCompression: 9.50:1Fuel system: Renix 4 fuel inj.Aspiration: NormalCatalytic Converter: YMax. output: 199.7 PS (197.0 bhp) (146.9 kW)@6000 rpmMax. torque: 260.0 Nm (192 lbft) (26.5 kgm)@3600 rpmCoolant: WaterSpecific output: 66.2 bhp/litreSpecific torque: 87.39 Nm/litrePerformance0-60mph: 7.9 sQuarter mile: 16.30sKilometre: 28.60sTop speed: 235 km/hPower to weight: 135.02 bhp/tonChasisEngine location: FrontEngine alignment: UnknownSteering: rack & pinion PASTurning circle: 12.00 mSuspension front: I.MS.LW.CS.ARB.Suspension rear: I.DW.CS.ARB.Wheels F/R: 7J x 16/7J x 16Tyres front: 205/55 VR 16Tyres rear: 205/55 VR 16Brakes: VeDi/Di-S-ABSBrake diametre: 276/290 mmTransmission: 5MDrive: FWDTop gear ratio: 0.77Final drive ratio: 4.07 Quote Link to comment Share on other sites More sharing options...
august Posted October 18, 2005 Author Report Share Posted October 18, 2005 another interesting page: http://www.autoweb-france.com/index.php?rub=3&essai=137 PRV motor huh? was it a PRV block with the fancy Mi16 style multi pipe head? Quote Link to comment Share on other sites More sharing options...
JunktionFET Posted October 18, 2005 Report Share Posted October 18, 2005 Yes it was the 3.0 liter PRV--has a larger bore than the 2.8 we are familiar with. From what I understand, only the Peugeot version of the motor used the heads with the 12 exhaust ports... the Citroen version of the car allegedly did not. In fact, I don't even think a 24 valve version of the motor was used in the Citroen. I don't know for sure though. Anyway, despite whatever problems the 605 may or may not have had, I think it is an attractive car and probably not to shabby to drive either. One overseas road test preview I read in Car & Driver indicated how well balanced the car was. Though he did think the power steering might've been a bit too boosted given the character of the car in general, I do remember the comment that he was genuinely unable to tell where the drive wheels were. That is an impressive comment for a FWD car housing a large torquey motor. This is a cutaway image of the engine where you can see part of one of the headers http://www.peugeotclub.org/peugeot/images/605v24.jpg I've seen other pictures that have the engine all polished up--very pretty. I'm sure there is a lot of power potential locked away in that motor, like the Mi16. Quote Link to comment Share on other sites More sharing options...
august Posted October 19, 2005 Author Report Share Posted October 19, 2005 badass no doubt.. I wonder why they went to the ES non prv motor in 95. PRV licencing maybe? Quote Link to comment Share on other sites More sharing options...
JunktionFET Posted October 19, 2005 Report Share Posted October 19, 2005 The PRV motor is a 90 degree design and I'm sure that made it difficult to fit in smaller FWD cars. The new ES V6 is 60 degrees, and I believe it is also lighter. Plus with it being a new engine, they can attach the buzz words "ALL NEW" to it and make it more appealing. Of course, that would be for the dumbed-down North American market. Perhaps they are more sensible in Europe? Quote Link to comment Share on other sites More sharing options...
