I collect some answers here:
Pin is from volvo 23mm so that have to be re-done also for conrod top.
Engine is Volvo B 230 FT also 230 ET will do but ET has smaller space in piston top. I'll have next week also set of ET pistons so I'll measure that to make it sure.
That engine is used in 240,740,940 series
In macinery shop gyus where bit confused when I requested that "grind this to 96mm" usually 2mm is max from original size. and now this is more than 4mm. Of cause walls are rather narrow now you can hear when knoking by finger inside of cylinder and comparing it between original and grinded one.
No I'm no reseller, I have grind model for dani cam and I have sold my used one (of cause) and re done new for my self (I do know law).
Only diffrence is from dani stage 1 to stage 2 is head. And seems at also dani original head has that same weaknes as normal ones. FPR is 3.2bar in dani set, it is normal 2.5bar FBR but has been pressed from top. actuator is stiffer. Rockers are standard in std and dani head. But grinded of cause has different "hit" angle to cam, that could be softened by using slash cabs ~2mm thikness is enough.
Low rev. torgue is expected also and hp should not go over 300hp from engine, I have fear at torgue is over 450Nm and clutch will go off. If I buy this SPEC 0032 or 0033 clutch then gear or diff will give up.
I'd have some speed up with std Cosworth sierra with my old set up Dyno curve and I get skin of head but it was close... but coswoth does 0-100 in 6.5sec and it did loose when we change to 2gear and speeded up, not much but still.
V-M
