John Posted June 8, 2007 Report Share Posted June 8, 2007 I have an '85 N9T with a suspect head. It was already repaired (cracks) by the PO just prior to my ownership but it now appears to be failing again. I really don't want to get into the engine right now so I am going to try a miracle cure in a bottle but in the event that I do try and fix the motor what is the interchangeability of the heads on these N9T variants? Regards John Quote Link to comment Share on other sites More sharing options...
V-M Posted June 8, 2007 Report Share Posted June 8, 2007 I have an '85 N9T with a suspect head. It was already repaired (cracks) by the PO just prior to my ownership but it now appears to be failing again. I really don't want to get into the engine right now so I am going to try a miracle cure in a bottle but in the event that I do try and fix the motor what is the interchangeability of the heads on these N9T variants? Regards John They all fits 100% V-M Quote Link to comment Share on other sites More sharing options...
Pugsley Posted September 2, 2007 Report Share Posted September 2, 2007 Some of the shify used car dealers use an additive that runs about $85-100 that will supposedly repair a leak. Ive been told it works , also. Quote Link to comment Share on other sites More sharing options...
V-M Posted September 3, 2007 Report Share Posted September 3, 2007 Some of the shify used car dealers use an additive that runs about $85-100 that will supposedly repair a leak. Ive been told it works , also. WOW... thats expensive additive (here those cost between 20-30e) Only welding and needed valve work cost's around 250-300e + sending costs. And thats only longtherm solution. Those additives are bit dangerous cause thos are reacting with oxygen and is filling also pipes in radiator (not nice in hot countries) and inside heating element (not nice in cold countries). Specially in those engines where is block heating element that is realy destroying that element. I can only recomend those "REPAIR" additives usage when travel/trip is disturbed and there is no other possibility fix broblem. IMHO NOTE. I'm not saying at those don't do that job, but there is some unwanted side effects. V-M Quote Link to comment Share on other sites More sharing options...
Pugsley Posted September 4, 2007 Report Share Posted September 4, 2007 I agree; it is a band-aid for a shotgun wound but, I have heard of cars running over two years with it. But, the cooling system will look like cement. Shame parts avability with the N9T is slim to none; and the heads seem so crack prone. Quote Link to comment Share on other sites More sharing options...
