Guest the505inme Posted April 3, 2006 Report Share Posted April 3, 2006 I have a faint battery light glowing prob. With a volt meter hooked up directly to the alternator, it reads 13-14 v in the city, then up to 17-18 on the highway. Therefore, it's the voltage regulator, right? But could it be bad wiring? It already has a new battery, B+ wire, and terms. I already had the alt out and tested at an electrical shop, they said it was fine. Could they have missed the bad regulator? I need to figure this out soon, need the car this weekend. Quote Link to comment Share on other sites More sharing options...
august Posted April 3, 2006 Report Share Posted April 3, 2006 I have a faint battery light glowing prob. With a volt meter hooked up directly to the alternator, it reads 13-14 v in the city, then up to 17-18 on the highway. Therefore, it's the voltage regulator, right? But could it be bad wiring? It already has a new battery, B+ wire, and terms. I already had the alt out and tested at an electrical shop, they said it was fine. Could they have missed the bad regulator? I need to figure this out soon, need the car this weekend. strange.. i'm no electrical engineer, but i'd still lean twords the alternator. I can't see how fault wiring would lead to the voltage regulator not doing its job correctly. where do you live? if your in the area i'm sure i have a spare alternator you can try. anyone else have any ideas? Quote Link to comment Share on other sites More sharing options...
Guest the505inme Posted April 4, 2006 Report Share Posted April 4, 2006 strange.. i'm no electrical engineer, but i'd still lean twords the alternator. I can't see how fault wiring would lead to the voltage regulator not doing its job correctly. where do you live? if your in the area i'm sure i have a spare alternator you can try. anyone else have any ideas? I'm in Toronto, Ontario, Canada. Quote Link to comment Share on other sites More sharing options...
