1 B 505 Posted May 7, 2009 Report Share Posted May 7, 2009 Hi has anybody seen or heard about this problem before? I have a 1989 505 Turbo automatic and in the morning when the car is cold it starts right away but if driven will not shift upwards out of the 1st gear at any RPM. However, after running idle for 5-10 minutes, it will work fine and go through all gears without a problem. So, all it takes is an idle run for 5-10 minutes and then the car is fine... Any thoughts? Thanks. Quote Link to comment Share on other sites More sharing options...
bill Posted May 7, 2009 Report Share Posted May 7, 2009 George Nunez on The List says it might be the governor sticking in first: RE: [Peugeot-L] 505 SW8 Transmission Problem Yeah....try changing the fluid a few times. and an additive .....it prob the governor sticking in first. -----Original Message----- From: Benjamin [mailto:hakim_fahd@...] Sent: Sunday, January 30, 2005 11:29 PM To: [email protected] Subject: [Peugeot-L] 505 SW8 Transmission Problem This week I took my wagon to replace ATF lines that goes to radiator, after install new lines, it takes long to shift 2nd (up to 3000 RPM) after 2 or 3 times, it shifts well. I verified fluid level and it seems to be overfilled, do you think that this is causing the failure? Do you have any clue what to do? Transmission was working smoothly before ATF lines replacement. Transmission is ZF 4HP22 4 speed. Thank you. Ben Quote Link to comment Share on other sites More sharing options...
1 B 505 Posted May 8, 2009 Author Report Share Posted May 8, 2009 George Nunez on The List says it might be the governor sticking in first: RE: [Peugeot-L] 505 SW8 Transmission Problem Yeah....try changing the fluid a few times. and an additive .....it prob the governor sticking in first. Thanks George, I will try that this weekend. Radu. -----Original Message----- From: Benjamin [mailto:hakim_fahd@...] Sent: Sunday, January 30, 2005 11:29 PM To: [email protected] Subject: [Peugeot-L] 505 SW8 Transmission Problem This week I took my wagon to replace ATF lines that goes to radiator, after install new lines, it takes long to shift 2nd (up to 3000 RPM) after 2 or 3 times, it shifts well. I verified fluid level and it seems to be overfilled, do you think that this is causing the failure? Do you have any clue what to do? Transmission was working smoothly before ATF lines replacement. Transmission is ZF 4HP22 4 speed. Thank you. Ben Quote Link to comment Share on other sites More sharing options...
