Guest Posted June 29, 2005 Report Share Posted June 29, 2005 My 81 505 TD has coolant leaking from under the manifold just below the coolant tank. This started just after I filled up a month ago and I have not driven it since. (I do have other cars to drive.) The symptoms go like this: On the freeway at about 65mph I heard a bang like something hit the underside of the car. I looked into the rearview mirror to see a lot of white smoke that did not last long. Fearing a blown engine I watched the gauges as I slowed down. I was about a mile from home and the only gauge to move was the temp. That told me something in the cooling had blown. I got home before the temp got into the red and lifted the hood to try and see just what had happened. The only place I could see any coolant was under the coolant reservoir and in top of the turbo. I checked the hoses going to/from the firewall and found no leaks. My question is: Since the engine was running fine before this happened, could this be a freeze plug that has rusted through? It has been loosing coolant (about 2qts a month) for about a year before this happened. I am not sure that I want to go to the trouble of replacing just one freeze plug as I am not sure just where they ALL are. Quote Link to comment Share on other sites More sharing options...
