10PARUE Posted June 16, 2016 Report Share Posted June 16, 2016 NOS would be nice! Or good used. Does anyone know, are there any non-Peugeot, mechanically compatible units? /jwc Quote Link to comment Share on other sites More sharing options...
Brian Holm - Parts for Peugeots Posted September 14, 2016 Report Share Posted September 14, 2016 I have good used ones, may have a new one. Quote Link to comment Share on other sites More sharing options...
eboy999 Posted March 13, 2017 Report Share Posted March 13, 2017 Just on the subject of 505 electric windows in general. I found that (at least in pre-86) the issues was 100% of the time the switch (for me). Of course I was obsessive enough to even replace the lights inside the window switches, which burned out often enough. And they were super easy to remove in the original interior style. Switches were (then) not expensive, and bulbs even less. However, if you are diligent and detail oriented enough, you can refurbish a window switch. You WILL most likely need a dremel and good quality adhesive, as inevitably plastic parts will break upon disassembly. If anyone has a secret to doing it without breaking at least one plastic tab off, that would be cool to share. Quote Link to comment Share on other sites More sharing options...
