MrControl Posted May 25, 2006 Report Share Posted May 25, 2006 again, i have to apologize for my not so good English, but i hope you understand what i need help for. My 505ti 2.2 88 model has a problem that it cuts the electrisity to the coil.. earlier it used to stop after a 5-15min but now it wouldnt even start.. i have changed the rotor, coil, coil plugs, ignition module, any answer is appreciated:) Quote Link to comment Share on other sites More sharing options...
Guest broke Posted May 27, 2006 Report Share Posted May 27, 2006 Are you driving an 1988 turbo gas if so.......... This is a shot in the dark...........check your ignition relay Quote Link to comment Share on other sites More sharing options...
MrControl Posted May 28, 2006 Author Report Share Posted May 28, 2006 Are you driving an 1988 turbo gas if so.......... This is a shot in the dark...........check your ignition relay hm thank you for answer.. where can i locate that relay? Quote Link to comment Share on other sites More sharing options...
Guest broke Posted May 30, 2006 Report Share Posted May 30, 2006 hm thank you for answer.. where can i locate that relay? In your engine bay next to the brake reservoir there are 2 little black relays side by side. One of them is for the ignition the other for the injection (fuel). Quote Link to comment Share on other sites More sharing options...
