Finally got coolant lines, power steering and braking figured out.
What kind of lubrication does the vacuum pump take. I was told by previous owner of the engine to fill with atf so I filled it half way but it puked fluid out the front seal when running. Am I filling it wrong or is the front seal on the pump bad?
Side questions:
Am I doing any damage using a <10 psi pump to feed the engine, will the excess fuel go out the return line?
Is there any method you recommend the correctly set the injection pump timing and fast idle cold start adjustments?
