Here's the car I'm looking at. The seller is asking $700. It runs pretty strong, handles nicely, comes with a block heater, and had anti-rust oil treatment applied. There are some things that need attention.
-Needs a good vacuuming!
-The transmission is stuck in third. The shifter moves into neutral, 2nd, 4th, and reverse, but the car stays in third.
-A/C pump is loose because it is missing a bolt.
-The car may need a head gasket replacement. After driving it I notices some milkyness on the underside of the oil fill cap. Owner says he does not notice any oil consumption, nor did I see any smoking. The coolant in the overflow bottle looks OK (no bubbling or milkyness).
-The speedo cable is broken. Odo is stuck at 240k km (car came from New Brunswick). Owner estimates he put another 2k-3k miles since that broke. -Seller recently replaced one of the fuel pumps with a Bosch unit, but for some reason it's noisy.
-The fuel gauge flutters during acceleration. I'm not sure the stock oil and water temperature gauges are working either.
-Stalk-mounted horn doesn't work. Owner jury-rigged a horn button.
-Some rust starting to form on right side rocker panel at the rear fender...
...under the lip of the trunk...
...and just under the front passenger's door.
-There's also some painted over spots on the hood and rear right fender. There's no body filler as far as I can tell though.
-Some bubbling on front right alloy.
-Grille is loose.
-Sunroof liner missing. Needs help when opening and closing. It doesn't leak, however, which is good since I rarely use the sunroof on my cars anyways.
-No fog lights or lower Turbo air dam. Were these optional on the '86s?
So, it's scruffy but not a total rustbucket. My big concern is the possibility that it needs a new head gasket. I can handle the transmission swap and fuel pump myself, but I would need a shop or helping hand to tackle the head gasket. No matter what, it has to be ready for winter time.
So, what sayeth the 505Turbo.com commentariat? Worth the $700 and some elbow grease, or leave it alone?
