mcNesse
mcNesse's Achievements
  1. Hi Rabin! Thanks! I will check this out and let u know how it went André
  2. Hi! I´ve just started a job on a 505 GTDT 1986 and run into some problems. When the ignition is OFF, the clock on the dashboard works, the buttons under the clock (seat heat, emergency lights etc.) works, the window-elevators works and the heat fan works. But when i turn the ignition ON, then nothing of the mentioned things work. But the instrument-panel works and the car starts if I turn the key so far. I´ve tested with another ignition-lock with the same result. Also it seems that all the relays are working. Have anybody had this problem before? Maybe a fix to the problem? Thanks! - André
