I have a issue with my V6 with hot wire air mass. The adjust screw just spends without any adjustment,seems stripped out,not sure! It looks like the screw makes a electric connection , Factory repair manual says it a air bleed screw, it sure does not look like it from the inside near the hot wire. Any way I had no vacuum leaks good fuel pressure,wires and good plugs. Have a lean misfire with injection good. Also i set the throttle to put her in the run mode. My o2 sensor works ok. The idle valve works. Without hurting fuel milage does any one know a trick? I was thinking putting a restrictor in the air boot side of the idle valve. I have enough RPM to do this. My friend said the Volvo model 89 V6 runs to lean at idle also. I have the same fuel pump as knew she was new. Thinking a Pump and O2 will be the next parts she will get! Thanks for the read. Frank in the bay area
