norcal505 Posted April 24, 2008 Report Share Posted April 24, 2008 Cool. Never would have thought of all places, in America, would have such engines built. Free shipping!! http://usedautoparts.everdrive.com/SearchParts.aspx http://usedautoparts.everdrive.com/PartDet...earchid=3814993 http://usedautoparts.everdrive.com/PartDet...earchid=3814993 Quote Link to comment Share on other sites More sharing options...
august Posted April 25, 2008 Report Share Posted April 25, 2008 no way in hell they would have N9TEA engines. at this point, if i were to buy an engine that was rebuilt, i'd want it be done by a reputable mechanic. like, the guy who built the race engine that's in victor's "red". yeah, the engine that was supposed to last only a few races, but has been going for over 100k? and it's still the smoothest power / fastest (by far) stock 505 i've ever driven in. yeah, i'd like to shake that dude's hand. Quote Link to comment Share on other sites More sharing options...
N9TE Posted May 3, 2008 Report Share Posted May 3, 2008 no way in hell they would have N9TEA engines. at this point, if i were to buy an engine that was rebuilt, i'd want it be done by a reputable mechanic. like, the guy who built the race engine that's in victor's "red". yeah, the engine that was supposed to last only a few races, but has been going for over 100k? and it's still the smoothest power / fastest (by far) stock 505 i've ever driven in. yeah, i'd like to shake that dude's hand. Anything you know he did different/unique? Victor? Quote Link to comment Share on other sites More sharing options...
SSB Posted May 5, 2008 Report Share Posted May 5, 2008 Mitch Wright, who ironically became the tech official for SCCA, built it. As he knew that SCCA was going to disqualify any engine that was touched at all he said he only built it "loose". What does that mean? I'm not 100% sure but he did say that you could turn the crank of the short block by hand. I had dto buy around 18 pistons to get 4 that weighted less than 1/4 grahm differance. I believe that the rods are the ones without the oil squirters as then the piston doesn't have to move the resultant oil out of the way. The squirters were supposed to reduce the heat in the pistons (read detonation) but apparently that's not an issue as Red has put 100,000 miles on that engine that was supposed to last just long enought to cross the finish line. Over the years since 1989 I changed the cylinder head (overheated on the racetrack), water pump & radiator, and here recently we did a valve job but only because the valve guide seals were not functioning anymore. And Red still show a pair of smokey rear tyres to all that chase. Quote Link to comment Share on other sites More sharing options...
Johnny Posted May 5, 2008 Report Share Posted May 5, 2008 Those squirters you talk about, is it the part I marked on this picture? Is it possible that those rods without was only on the N9T's? Quote Link to comment Share on other sites More sharing options...
SSB Posted May 6, 2008 Report Share Posted May 6, 2008 It's been some time, however I remember them as being actual nozzels counter sunk into the rod. Same location, I think. There may have been also the hole in the top of the rod as well. The idea was so that the piston didn't have to move so much oil out of the way. What you have identified, I believe, would have shot the side of the cylinder on the thrust side. Quote Link to comment Share on other sites More sharing options...
norcal505 Posted May 6, 2008 Author Report Share Posted May 6, 2008 awesome info. do you think you could possibly show us some bay pics? also, maybe some vids! smkoke those tires!! btw, you still have deuce? I might be intersted. Please email me, you have my address. Quote Link to comment Share on other sites More sharing options...
Johnny Posted May 6, 2008 Report Share Posted May 6, 2008 It's been some time, however I remember them as being actual nozzels counter sunk into the rod. Same location, I think. There may have been also the hole in the top of the rod as well. The idea was so that the piston didn't have to move so much oil out of the way. What you have identified, I believe, would have shot the side of the cylinder on the thrust side. Ok, I was wondering since I have rods without that hole also. Quote Link to comment Share on other sites More sharing options...
Pugsley Posted January 5, 2009 Report Share Posted January 5, 2009 Mitch Wright, who ironically became the tech official for SCCA, built it. As he knew that SCCA was going to disqualify any engine that was touched at all he said he only built it "loose". What does that mean? I'm not 100% sure but he did say that you could turn the crank of the short block by hand. I had dto buy around 18 pistons to get 4 that weighted less than 1/4 grahm differance. I believe that the rods are the ones without the oil squirters as then the piston doesn't have to move the resultant oil out of the way. The squirters were supposed to reduce the heat in the pistons (read detonation) but apparently that's not an issue as Red has put 100,000 miles on that engine that was supposed to last just long enought to cross the finish line. Over the years since 1989 I changed the cylinder head (overheated on the racetrack), water pump & radiator, and here recently we did a valve job but only because the valve guide seals were not functioning anymore. And Red still show a pair of smokey rear tyres to all that chase. "loose" = greater clearanes between the moving parts. Less friction. Todays new engines are machined so tight at the factory they can use 5W-20 oil Maybe the squirters werent needed after that,less heat from less friction ? Quote Link to comment Share on other sites More sharing options...
Guest EUROTRASH Posted January 7, 2009 Report Share Posted January 7, 2009 Cool. Never would have thought of all places, in America, would have such engines built. Free shipping!! http://usedautoparts.everdrive.com/SearchParts.aspx http://usedautoparts.everdrive.com/PartDet...earchid=3814993 http://usedautoparts.everdrive.com/PartDet...earchid=3814993 They APPEAR to have a V6, picture and all... I wonder. http://www.everdrive.com/partdetails.aspx?sku=3242382 ok the pic is just generic Quote Link to comment Share on other sites More sharing options...
Pugsley Posted January 7, 2009 Report Share Posted January 7, 2009 They APPEAR to have a V6, picture and all... I wonder. http://www.everdrive.com/partdetails.aspx?sku=3242382 ok the pic is just generic Looks like a GM Quad 4 in the pic. Ive found that many auto parts places on line claim they have the part or they can get it , but when you go in there and talk to the counterman its a different story. Quote Link to comment Share on other sites More sharing options...
