FJB505sti Posted August 24, 2025 Report Posted August 24, 2025 (edited) Found a bellhousing adapter for the ba 10/5 transmission. Has anyone ever done this conversion. Was thinking about Chevy 4.3 v6 or even small block Chevy in my 1987 505 sti. Edited August 24, 2025 by FJB505sti Forgot to put my vehicle in the post. Quote
Jayden M Posted August 26, 2025 Report Posted August 26, 2025 I suspect the only reason that bell housing adapter even exists is because of the jeeps that came with the ba10/5. I'd also be worried about the torque of a small block being too much for the ba10 to handle. Doubt anyone has ever done that conversion before, although there has been some turbo setups done to the v6 engine that comes in the car. Quote
FJB505sti Posted August 26, 2025 Author Report Posted August 26, 2025 Was thinking GM 4.3 turbo setup. Quote
SRDT Posted August 26, 2025 Report Posted August 26, 2025 The BA10 wasn't particulary suited for a big Jeep going off road, the 224 lb⋅ft from the 4.0 L6 didn't help either. Instead of a V6 you could try the AMC 4.0 L6 or even the AMC V8, the AMC bellhousing is very cheap unlike the GM one. Quote
Emile Clackson Posted June 16 Report Posted June 16 Seen it done a few times. The 4.3 is the smarter swap fits easier, doesn’t beat the crap out of the BA10, and you keep some weight balance. Small block will work but that transmission is glass behind a V8. You’ll snap it if you drive hard. Adapter plates are out there, usually from the Jeep guys. Motor mounts you’ll have to fab. Clutch fork clearance can be tight. It’s not bolt-in, but doable if you can weld and measure. Expect wiring and exhaust to be a headache. Would I do it? Only if my 505 was a beater and I had a spare trans. Quote
