Bean Posted March 27, 2007 Report Share Posted March 27, 2007 Yeah - you can't "adjust" for offset with camber or caster... You can try to tune out some of the issues, but too much offset is really nasty to drive and nothing you do to compensate will help. Keep in mind that if you have a wider wheel the offset amount changes with the width. So you really want to look at the backspacing measurement and ensure that you have the same backspacing as the stock wheels. With the wider wheel the pivot point on the contact patch is going to be buggered and having adjustible camber and caster will help tune issues that arise from that. Sadly with the one piece hub / strut assembly's in the older cars you are limited in the suspension geometry. Newer 505's (88 and 89's) have a more traditional 2-pc strut and hub set up so it might be easier to fit bigger wheels to those cars... Great work so far - and I like the style of wheel you want! Rabin Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted March 29, 2007 Report Share Posted March 29, 2007 I'm going for a two brake master cylinder's setup. I'm not quite shure wether I'll use a fixed, 2 pushrod transfer from the pedal to the masters, and use a adjustable bias valve for the rear circuit, or if I'll try fitting a balance bar... It's kind of narrow between the pedals, dont know if a balance bar will fit... Quote Link to comment Share on other sites More sharing options...
Bean Posted March 29, 2007 Report Share Posted March 29, 2007 Balance bar usually fits right at the master cylinders - so if you mount and external box to house the master cylinders, the space that now holds the booster can be used to set up the balance bar assembly. I've seen this done for an old Volvo rally car project, and it was quite a trick set up - complete with hydraulic rear parking brake using a clutch master to actuate the rear brakes... (Brake line goes "through" the clutch master for normal braking - but when you pull the lever it actuates the clutch rod which "brakes" the rear calipers....) Hope you're able to do one or the other - having bias control would be great. Rabin Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted March 30, 2007 Report Share Posted March 30, 2007 recieved the seats and muffler: Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted April 2, 2007 Report Share Posted April 2, 2007 I'm going for a sellholm brake assembly with two master's and a balance bar. I'll buy it as soon as I can afford to... Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted April 4, 2007 Report Share Posted April 4, 2007 took the car out of the garage today, removed front and rear bumper's, it'll soon be ready for a new paintjob. I'll have to do something with the suspension, as the current ride height is extreme! I can fit my head between the tire and fender in front (why would I do that...?) I'll post some pictures soon.. Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted April 11, 2007 Report Share Posted April 11, 2007 Have started the restoration bit of my project, luckily, there's just a small amount of body rust on the car. I'll try to get it fixed today. will start cleaning and preparing the car for paint as soon as I get the engine out. Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted April 30, 2007 Report Share Posted April 30, 2007 Engine's out, Hopefully I'll get the car painted in a few week's... Any suggestions for color? something that does'nt crash totaly with the red seat's, was thinking of black (boring though...) Quote Link to comment Share on other sites More sharing options...
Bean Posted May 1, 2007 Report Share Posted May 1, 2007 A nice darker blue, or and "electric" blue would go nice with the red seats, you could then tie in details to the red accents on the car. (Silicone hoses, or painted suspension/brake bits in red) I'm also partial to motorsports white with the classic Peugeot Sport racing colours... But that kind of depends on the wheels (and colour) and tires you'll be using too. Tough decision picking colour - so good luck! Rabin Quote Link to comment Share on other sites More sharing options...
Justice Posted May 2, 2007 Report Share Posted May 2, 2007 @adegnes: Black (even matte) would look awesome on a 505. The chrome will really stand out, but make sure your rims are spot on, since they will get a lot of attention when you are driving a black car. White would be a good color aswell, won't clash with red either. Can't beat a good looking white car. Silver is also an option, good color if you don't like cleaning your car a lot. I found out it looks clean for a long time. Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted May 2, 2007 Report Share Posted May 2, 2007 I'll go for black. Currently doing some work on a honda civic front I got hold of, looks like it's going to fit pretty good with some drastic cutting... Almost done preparing the car for paint, need the front driverside door (my mother hit my car, severely damaged the old door) I'll post some pic's tomorrow. Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted May 4, 2007 Report Share Posted May 4, 2007 A picture of the civic front I'm working on. Needs some more trimming under the headlights (to get it leveled with the lights, and the fender, it's currently a 1cm gap between the lower edge of the fender and the bumper) and in the back (the original curve of the bumper actually follows the line of the wheelarch perfectly,it only needs to be cut, and moved about 2cm forward cause the bumper builds more backwards than the oem one) the leftovers from the civic grill will be cut to go clear the stock grill, and hid behind it.. Look's like it's going to fit preety well! what do you think? Quote Link to comment Share on other sites More sharing options...
Johnny Posted May 4, 2007 Report Share Posted May 4, 2007 Looks cool! I look forward to seeing the final result. Quote Link to comment Share on other sites More sharing options...
Bean Posted May 4, 2007 Report Share Posted May 4, 2007 Looks like a great start for sure! Look forward to see the final fit and finish. Rabin Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted May 12, 2007 Report Share Posted May 12, 2007 got hold of a new door. It was ALOT of work to get it to fit propperly (turned out the doorhinches was bent preety bad...) I think I'll have to do some serious cutting under the headlights to fit the intercooler pipes.... Quote Link to comment Share on other sites More sharing options...
Bean Posted May 12, 2007 Report Share Posted May 12, 2007 Looks awesome with that big IC up front! I'm also jealous of the biode euro headlights... (Separate high beam bulb and reflector instead of the singe H4 bulb in the ones we get here.) Nice job on the door fitment too. The pins are the usual suspects when they don't hang well - but if you had to fight bent hinges too then that would have been nasty. Rabin Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted May 18, 2007 Report Share Posted May 18, 2007 my car will be painted 28th of may, It'll cost me ca. 650USD (for the whole car, inside and outside), wich is fairly cheap considering paintjob-prices here in norway... Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted June 18, 2007 Report Share Posted June 18, 2007 Will pick up my car tomorrow also, a friend of mine has a T3T4 hybrid turbo in good shape for sale; 250$ cheap! Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted June 21, 2007 Report Share Posted June 21, 2007 My car's back! The paintjob turned out ok, I could have been better with the pre-work, there's a few dent's I overlooked, and some areas shows sloppy filler work... but hey, it was my first time ever preparing a whole car for paint! I'm happy, and now I can start putting it back together... Quote Link to comment Share on other sites More sharing options...
Johnny Posted June 21, 2007 Report Share Posted June 21, 2007 Pictures please? Quote Link to comment Share on other sites More sharing options...
Guest adegnes Posted June 22, 2007 Report Share Posted June 22, 2007 Pictures please? coming.... I forgot my camera yesterday... Quote Link to comment Share on other sites More sharing options...
norcal505 Posted June 23, 2007 Report Share Posted June 23, 2007 Volvo 4 piston calipers bolt onto the Pugs with no problems (need the 240 Turbo calipers or the ones for vented disks) but they'd be a nice cheap upgrade. (Heavy - but good.) Rabin 240 Turbo Calipers?? To my experience....they're pretty much the same as n/a 240's.. Depends though... your right about them (different from 86+'s, but theyre shared with the gt, glt, and 262 bertone editions, to my knowledge. My 92 245 has slight upgrades, and I am soon goin' to convert the whole thang (calipers/hoses/brembo rotors/adaptors) to the S60R brakes. A friend of mine, dave barton, had the conversion on his car.... here's the site...Dave Barton of SoCal's R Brake Conversion But are you sure about the 244/245 TIC brakes fit perfectly on 505's?? Because If youre right, I mite throw on my set that I accurried from another local Turbobricker.. Quote Link to comment Share on other sites More sharing options...
Bean Posted June 24, 2007 Report Share Posted June 24, 2007 I've only done the research - never actually bolted them up. As for NA Volvo's - as long as they're vented front disks they'd work fine. I've got an old 240 wagon and it has solid disks - so the calipers won't fit. Since Turbo 240's all had vented it's easier to just refer to that model. The only think is that the old Volvo calipers need two lines to it - making it a PITA to fit. Be neat to see what it's like though if you try it... Rabin Quote Link to comment Share on other sites More sharing options...
norcal505 Posted June 25, 2007 Report Share Posted June 25, 2007 Hey rabin any pic(s) of your 245?? P.M. me!! As for bolting em' up, my neighbor has a 87 245DL, and he said that he has Turbo Calipers on it. As for the turbo part, I guess you could call my car a 92 turbo. garrett t3 baby!! it is a very simple conversion...called B230F+T. As for the boost, not that much yet, after all, its a a "junkyard conversion" using 700 seiries parts..lol Quote Link to comment Share on other sites More sharing options...
Bean Posted June 25, 2007 Report Share Posted June 25, 2007 Oh dude you'd cry if you saw this beast... It's about a week away from being donated if it doesn't fire up and run decent this week. (It's been sitting for over a year so I'm not holding out much hope!) If it does run decent I need to go through it to see if it passes safety (or can fairly easily). If I can get it safetied and I can splash it with some paint I'll send some before and after pics. Rabin Quote Link to comment Share on other sites More sharing options...
