Paul Posted October 26, 2020 Report Share Posted October 26, 2020 In order for this engine to start and run : disconnect trigger wire from starter solenoid. Connect this wire to battery +12V Turn ignition switch to run. Connect jumper wire to starter solenoid and touch to +12V battery momentary for start. This puts +12V on Pin 4 the ignition ECU.If I remove the +12V from this disconnected trigger wire, engine quits. This has nothing to do with the tachometric relay as ll the engine has the same problem with the tachometric relay bypassed. I am beginning to think that the injection ECU has a problem, because looking at the fuel injector signal, it is not proper. I think that applying +12V to pin 4 of the Injection ECU is normally only done with ign. SW in start position, for longer pulse width to add fuel during start up. I am in the process of checking all inputs to both Injection and ignition ECU s. I would appreciate any ideas on this problem. Thank You .....Paul N9t_1985_fuel_injection_connection_pictorialF0.023.pdf Quote Link to comment Share on other sites More sharing options...
Bean Posted October 26, 2020 Report Share Posted October 26, 2020 Welcome to the forums Paul - That's some fantastic diagnostics for a first post too! 85's have been known to have had faulty ECU's with most folks finding a fix with a replacement ECU, but this is literally the first time I've heard of or read of your trick to get it to start! I had an 85' that was a no start, and I assumed it was the ECU but never had the chance to really test it out. With this new info however - Fixing the ECU shouldn't be that hard. I would wager that the ECU board has a cold solder joint or some other broken power path that is preventing pin 4 from getting power via the proper internal circuit. You'll likely need to open up the ECU to inspect for cold solder joints (cracked), or possibly a scorched trace or component on the PCB itself. These are such lovely cars and the series 1 1985 505 Turbo is such a neat car. Lots of cool one-off stuff on them like a bigger oil cooled turbo with a 5 bolt exhaust flange, and sodium cooled exhaust valves. Rabin Quote Link to comment Share on other sites More sharing options...
