Mr_rye Posted September 25, 2020 Report Share Posted September 25, 2020 That's right! Selling the car because it doesn't get much love these days due to other projects. The car runs and drives well, starts fast even in cold weather. XN6 gas engine w K-Jet, BA7/5 5 speed manual transmission. new front brakes, new brake master/remaned booster, new Bosch inline fuel pump, new Delphi lift pump in the tank, gas tank cleaned of all rust (from filler neck lol), new plugs/cap/rotor/wires, ign dizzy vacuum advance works, repacked wheel bearings up front, rebuilt starter, fairly fresh oil in the air filter, new tires (as of 2018), grounding trees cleaned, WUR cleaned and functional,fuel dizzy/injectors tested and within spec, factory mag wheels and steel spare, factory jack, trailer hitch, new shifter link. The bad stuff: interior and leather seats are pretty sad, some rust spots under the hood, EGR and cruise control deleted (needs a one piece speedo cable!), DOT headlight assemblies are falling apart, fuel gauge not terribly accurate due to use of a 504 fuel sender, passenger seat heater not working, some dash accessory switches broken, A/C compressor present but seized, lug nut missing front driver side, rear door handles broken/missing, paint job sad...... $2000 OBO I'm located in Central New Mexico/Albuquerque Metro area Quote Link to comment Share on other sites More sharing options...
Mr_rye Posted September 25, 2020 Author Report Share Posted September 25, 2020 underhood Quote Link to comment Share on other sites More sharing options...
Bean Posted September 25, 2020 Report Share Posted September 25, 2020 Way too far away to even consider, but I’m guessing little to no rust? Glass good? Paint is toast but seems like a decent candidate to save as it looks well sorted mechanically and the MANUAL series 1 XN6 wagons are very rare... Hate to say it - But it’d be worth decent money to an exporter that is sending cars to Africa - Might be worth checking into. Rabin Quote Link to comment Share on other sites More sharing options...
