Goce Posted September 10, 2021 Report Share Posted September 10, 2021 Hi everyone, i've miss this thread and i've been down this road. The brown or black sensor under the thermostat is the one for the fans, and there are two available from peugeot one for petrol cars and one for diesels, the difference is in ohms diesels switch the fans sooner. Blue or green sensor with bosch conector is the one for the ECU and the temp gauge reads from it as far as i know. The one wire red top sensor with open terminal or bosch connector dependent of the year is for the overheat light on the dashboard. As you said they are all on the thermostat housing. The coolant level sensor is on the radiator under the neck for filling the radiator. I've had trouble with my temp gauge, changed the sensor no change mine was reading cold, and then i found a loose ground in the dashboard. You can add a resistor to correct your reading ether in the gauge cluster or at the sensor connector. Quote Link to comment Share on other sites More sharing options...
91MR2 Posted September 11, 2021 Author Report Share Posted September 11, 2021 16 hours ago, Goce said: Hi everyone, i've miss this thread and i've been down this road. The brown or black sensor under the thermostat is the one for the fans, and there are two available from peugeot one for petrol cars and one for diesels, the difference is in ohms diesels switch the fans sooner. Blue or green sensor with bosch conector is the one for the ECU and the temp gauge reads from it as far as i know. The one wire red top sensor with open terminal or bosch connector dependent of the year is for the overheat light on the dashboard. As you said they are all on the thermostat housing. The coolant level sensor is on the radiator under the neck for filling the radiator. I've had trouble with my temp gauge, changed the sensor no change mine was reading cold, and then i found a loose ground in the dashboard. You can add a resistor to correct your reading ether in the gauge cluster or at the sensor connector. Goce, thank you, this is great information, confirms/corrects a lot of what I was thinking. Once I have the parts, I will get right on installing them and update you guys… Quote Link to comment Share on other sites More sharing options...
91MR2 Posted September 19, 2021 Author Report Share Posted September 19, 2021 Ok guys, think I got the coolant temp. / fan situation all sorted. I replaced the fan switch/sensor today, and then topped up the coolant, and fired the car up. I let it idle up to temperature, and started watching carefully from that point. The car got up to right around 210, and then the fans came on and quickly brought the car back down to 190. I watched this cycle occur again before I was satisfied. Going to call this one fixed... Now on to the oil temp. stuff. Going to pull the cluster "soon" and swap the oil temp. gauge with a spare one that I have. Will update once I get to that... Quote Link to comment Share on other sites More sharing options...
91MR2 Posted September 19, 2021 Author Report Share Posted September 19, 2021 Including a little video for you guys here. There is no sound to the video for some reason, but watch the surge and return of the oil temp. needle. This is with the windows up, operating the switch under load causes the needle to move, and then when released, move back. Thoughts?  IMG_7760.MOV Quote Link to comment Share on other sites More sharing options...
Bean Posted September 20, 2021 Report Share Posted September 20, 2021 I bet your battery voltage is dropping under load, which causes the voltage across the resistance of the sensor to change… Put a voltmeter on it and I bet it does a similar blip.   Sound works for me btw. With engine running I’d wager it doesn’t move or move as much. Rabin Quote Link to comment Share on other sites More sharing options...
91MR2 Posted September 20, 2021 Author Report Share Posted September 20, 2021 45 minutes ago, Bean said: I bet your battery voltage is dropping under load, which causes the voltage across the resistance of the sensor to change… Put a voltmeter on it and I bet it does a similar blip.   Sound works for me btw. With engine running I’d wager it doesn’t move or move as much. Rabin So what does this mean then? By that I mean, what is the solution? Or possible solutions? This was done with the engine running by the way. Quote Link to comment Share on other sites More sharing options...
Bean Posted September 20, 2021 Report Share Posted September 20, 2021 Wow - it’s quiet.  Do a voltage meter just to see if the voltage is dropping.   Does it do similar when you turn your lights on?  (Or any other high load?) Only other thing would be ground circuits.  Making sure the grounds are all clean and in good shape helps all sorts of issues. Rabin  Quote Link to comment Share on other sites More sharing options...
91MR2 Posted September 21, 2021 Author Report Share Posted September 21, 2021 On 9/19/2021 at 11:28 PM, Bean said: Wow - it’s quiet.  Do a voltage meter just to see if the voltage is dropping.   Does it do similar when you turn your lights on?  (Or any other high load?) Only other thing would be ground circuits.  Making sure the grounds are all clean and in good shape helps all sorts of issues. Rabin  On 9/19/2021 at 9:45 PM, Bean said: I bet your battery voltage is dropping under load, which causes the voltage across the resistance of the sensor to change… Put a voltmeter on it and I bet it does a similar blip.   Sound works for me btw. With engine running I’d wager it doesn’t move or move as much. Rabin  Bean, thanks for the info. I am conversational at best when it comes to electrics, so I'm going to have to get my buddy over to help with some of this. I can at least start checking grounds and see where I end up. To be continued... Quote Link to comment Share on other sites More sharing options...
Goce Posted September 22, 2021 Report Share Posted September 22, 2021 I Can't see the video, not sure if it has been removed, but this sounds familiar, i've had a bad ground under the carpet at the driver's feet that moved my gauges with the side indicators, the bolt head rusted from water, clean the terminal, changed the bolt and it fixed my problem, you should test for both power and ground drop at the gauge. Quote Link to comment Share on other sites More sharing options...
91MR2 Posted September 23, 2021 Author Report Share Posted September 23, 2021 I'm not sure it's a bad ground, because this is the only gauge that is behaving this way. Sound logic? I'm really not looking to tear the interior/carpet out to find the problem here, but I suppose if I have to... I'm going to get into this soon again, it is the only "issue" the car has, so for now, I'll take it... Quote Link to comment Share on other sites More sharing options...
Bean Posted September 23, 2021 Report Share Posted September 23, 2021 Each gauge is basically in their own circuit, so while they may share a ground, they might not so I wouldn’t dismiss it being a ground issue especially in a Peugeot! Definitely check voltage changes when you do it however.   Rabin Quote Link to comment Share on other sites More sharing options...
91MR2 Posted October 29, 2021 Author Report Share Posted October 29, 2021 Gentlemen, happy halloween (almost)... Drove the car a good 100 miles or so today, didn't skip a beat. Well, except for the welds breaking from the cat to the midpipe, but fortunately I was able to take it to a muffler shop and they welded in a SS sleeve, and was back on my way again... Some pictures of it on the shores of Lake Erie... Â Quote Link to comment Share on other sites More sharing options...
91MR2 Posted November 25, 2021 Author Report Share Posted November 25, 2021 Happy Thanksgiving gentlemen. Drove my car a little bit since the last post, all is still well, minus the oil gauge discrepancies still (one day...). Also recently took the car to my interior guy, as a seam started to come loose on the driver seat, so he hand stitched it back to near new, can't even tell. Perhaps some photos to follow... Until next time... Quote Link to comment Share on other sites More sharing options...
91MR2 Posted December 28, 2021 Author Report Share Posted December 28, 2021 Boy, things have been quiet around here lately... Not much to report on my end from a Peugeot standpoint, however have a big project coming up in the spring that will indirectly help/benefit it, as well as all of my other cars... Going to do an addition on my garage to turn it from a 3 1/2 car garage into a full 5 car garage. New dimensions will be 55x22, up from 42x22. Here's maybe the best part - I also own the house next door, and will be building an open air breezeway to connect to the next door garage, which will now only be about 3 1/2 feet away. That garage is 26x22, and will hold 2 cars, plus my jet ski. So basically, all 7 of my cars, plus my Sea Doo, will now have storage all under basically one roof. Very exciting... Quote Link to comment Share on other sites More sharing options...
Bean Posted December 28, 2021 Report Share Posted December 28, 2021 That sounds AMAZING!  I’ve only got a 16x24 garage that I should have insulated and done up prior to moving in, but I didn’t, and have since filled it with parts and tools!  Sadly still in the midst of a multi-year project to wire and insulate it while it’s full of stuff - not fun! We looked at doing rental property so I could get a bigger working garage, but housing prices were just too high to make it worthwhile… Pics and updates on the garage would be awesome as well. Rabin Quote Link to comment Share on other sites More sharing options...
91MR2 Posted December 28, 2021 Author Report Share Posted December 28, 2021 Thanks Bean, indeed I am very excited and will certainly post progress photos. I know this sounds like a first world problem, and fully acknowledge that it is, however having several cars be scattered about in different garages has been a real pain. This project will truly allow me to tackle and manage so much more without all the annoying logistics… Quote Link to comment Share on other sites More sharing options...
91MR2 Posted February 1 Author Report Share Posted February 1 Gentlemen, hope you're enjoying winter as much as we are (sigh)... I haven't had much to report on here, but we did in fact get our permits from the city for our garage addition, so excited about that. Breaking ground in April if the weather allows. In other news, we got a call from our Lotus dealer the other day, that our allocation for a First Edition Emira has been honored. First US deliveries will be later than expected, likely towards the latter part of 2022, but that's ok, gives us more time to get the garage done. Hoping to go to the Philadelphia Radwood event with the Peugeot in the spring, but we will see where covid is by then... Quote Link to comment Share on other sites More sharing options...
Bean Posted February 1 Report Share Posted February 1 Very cool to hear about the Emira - but now I need to ask what spec you ordered?  I’m guessing it has to be a first edition so supercharged v6?  Manual?  Sport?   Absolutely LOVE the philosophy of this new car of theirs that’ll probably the last nod to the analogue sports cars of yesterday. Rabin Quote Link to comment Share on other sites More sharing options...
91MR2 Posted February 1 Author Report Share Posted February 1 Hi Bean, happy to indulge... Yes, First Edition, V6 supercharged, 6-speed manual transmission. I've settled on Nimbus Grey, but struggling on the interior, either going black leather or tan leather. The tan would make like a modern day version of my Esprit, as far as color combo, and I thought that might be really cool. But then, black interior is hard to say no to as well... I agree, I too love the philosophy. From all I can tell, it is basically an updated Evora, and while Lotus wants everyone to think this is an all new car, I think the former is a tremendous compliment. The Evora is an amazing car that truly doesn't get the credit it deserves... And yes, Lotus already said the Emira will be it's last ICE car...so I'm going all in on it... Here are come photos from the configurator, showing both options. Very torn... Â Quote Link to comment Share on other sites More sharing options...
91MR2 Posted March 7 Author Report Share Posted March 7 Howdy gentlemen - as we are closing up the winter season, we are now preparing for our garage addition in the coming weeks. Nothing to add now, but much more to add later. Will post updates here as they develop... Quote Link to comment Share on other sites More sharing options...
Bean Posted March 7 Report Share Posted March 7 Feel free to start a new thread for the garage if you want - I love garage builds and seeing how and what get done. Missed the pics of the interior and your dilemma!  I don’t envy the choice but give the nod so the brown as that darker tone of tan/baseball glove type colour just looks so good in anything.  Like tan I cannot abide by though! Rabin Quote Link to comment Share on other sites More sharing options...
91MR2 Posted March 9 Author Report Share Posted March 9 Thanks Bean, sounds fine, depending on the speed of the project, perhaps I'll make a new thread on it, if it's just a few noteworthy updates though, I'll just make sure the Mi16 is in the background of the shots, ha... Unrelated, we finalized our Emira order and went with the black leather interior. I'm sure it will age the best... Quote Link to comment Share on other sites More sharing options...
91MR2 Posted March 20 Author Report Share Posted March 20 Spent the last couple days moving cars around in preparation for our garage addition, rare to get photos of all the cars together. Even got my daughter to give the Peugeot its first wash of the year... Quote Link to comment Share on other sites More sharing options...
91MR2 Posted March 30 Author Report Share Posted March 30 Garage project fully underway now, all cars temporarily relocated, had to bring Peugeot to a friend's garage the other day. Much chaos for next couple months, can't wait until it's all done...updates to follow... Quote Link to comment Share on other sites More sharing options...
91MR2 Posted April 23 Author Report Share Posted April 23 Gentlemen, a garage build check in... I haven't driven a car in months, as we have been full go on the garage build. Rather than bore everyone with thousands of photos, here's a synopsis in 4 photos. Cars should be returning in a couple weeks... Â Quote Link to comment Share on other sites More sharing options...
