Found 4x140 to 5x100 Wheel Adapters
ofArc
Peugeot wheels are lug centric, so while you could likely use those I’m not sure you’d be able to properly center them since they’re bolted to the hub from the back side.
m14 would likely still be loose in the stud holes as Peugeot wheel studs have a decent sized splined interference fit.  Ideally you’d need some conical washers or bushings that centered the m14 bolts when tightening the adapter bolts...
These do look like a decent backyard adapters, but for $500 I’d want them done on a lathe and machined to center on Peugeot hubs.
