NinaYo401 Posted October 28, 2019 Report Share Posted October 28, 2019 I can’t seem to find any info on accessing the side marker / position indicator bulb, pictured. It’s not mentioned in the Haynes. after breaking my license plate lenses, I figure it’s worth asking. Quote Link to comment Share on other sites More sharing options...
NinaYo401 Posted October 28, 2019 Author Report Share Posted October 28, 2019 I broke it! The lens is attached with nuts and bolts through the fender. Hopefully the JB weld isn’t too black through the lens. a couple dabs where the bolts attachment broke. Hope that does it for a while. Quote Link to comment Share on other sites More sharing options...
Bean Posted October 31, 2019 Report Share Posted October 31, 2019 It sucks as those fasteners get so rusted they usually just twist right off, or break out of the plastic lens. Hopefully the JB weld works - I don't ever use that on plastic. Rabin Quote Link to comment Share on other sites More sharing options...
NinaYo401 Posted November 4, 2019 Author Report Share Posted November 4, 2019 Any insight into changing a sealed beam US spec headlight bulb? Quote Link to comment Share on other sites More sharing options...
Bean Posted November 4, 2019 Report Share Posted November 4, 2019 Sealed beams mean you replace the whole headlight. I’d highly recommend a quality e-code replacement like Hella or Bosch and then it will have a H4 bulb you can replace. To replace your have to remove the assembly and take apart the plastic housing on the back. Assembly comes out by popping the top corner closest to grill out, then the top corner on the fender side can come out of it’s ball socket. Adjuster rod inside can pop out, and there’s a spring on the bottom you have to unhook. Pretty easy. Rabin Quote Link to comment Share on other sites More sharing options...
