So meanwhile, I decided that the stainless steel license plate mount on the back of my Mercedes is very nice, heavy gauge and ideal for the 404C.  It will prevent the front plate from bending if it gets a "light kiss" in a parking lot, for example.  So I bought on from a wrecker, had to drill two holes to match the 404C bumper holes and mounted it.
This is much nicer than the original rusted one that I threw out some years back..which I later regretted.... but now I don't!
  • Replies 524
Long block comes home Thursday PM.  Of course one of the sets of rod bearings I dropped off there 5 days ago did the trick.........
Were all your rocker arms in good shape or did they have to redo / polish any of the hardened surfaces?
If so curious if they do them in house or if they send out...
Very exciting regardless!  Is there any goals this is a runner this summer?
They slightly refinished a few, likely extreme polishing - they were not bad in that respect - and all were re-bushed in house.
Plan is to get her running soonish and do some road trials whenever I can.  I expect the brake booster (NOS but it was on the car for 28 years) needs a rebuild but I'll probably try it as is for this stage of work.  Maybe I'll get lucky.  If not, it'll go to White Post in the eastern USA for a rebuild later this year.  It's nice to be winding down the costs of all this work, at this point.....
Next step now that it's home is to paint the block after getting the flash rust off it.  Also got from Peugeot Classic a Peugeot branded warning triangle and a plug wrench to carry in the car.
So far the only part of the block that was painted, after a good wire brushing, is the orangest part you can see in that photo.  I painted it before mounting the external oil line that feeds pressurized oil to the head, which would have made painting it pretty difficult after.  The tube itself needed painting and the insides were cleaned out first.
Ceramic paint good to 600°C on the cast iron manifold, which was perfectly rust free and clean beforehand. Hope it lasts a while!
65652
The other side.  The shop rectified the faces of the 4 ports on the manifold so it lost its mild pitting from the past 55 years and should fit the new head beautifully!
65653
I also cleaned the clutch fan switch sensor that screws into the radiator and mounted it, cleaned out the oil supply tube between the block and head, mounted it with new copper washers after painting the block behind the tube first, then painted the tube once mounted.
Block: satin black (originally unpainted).  Valve cover, timing gear cover in steel and sump are already powder coated gloss black.
Block is painted and some of the bits and pieces are attached.  Threw the header pipe on just for fun!
Mike, This looks fantastic !  Like everything else you have and had done to this 404C.
Thanks!
Today I got four new belts from Dean Hunter in England: one of the 1280.01 unadjustable water pump belts and three of the super short 5750.18 alternator belts that are common to 1965-1967 404 KF2 engines.
Got a few minutes today to mount the flywheel and then attach the frame for the engine stand.  And now it's on the stand so the reassembly can resume in earnest.
Got some assembly done today: timing gears, injection pump, housing and timing cover.  Next up is valve cover, oil pump/distributor drive and then sump.....
Lining up the timing marks:
Tensioner:
Injection pump with NOS SEDIS drivebelt, correctly tensioned:
All buttoned up:
Another view so you can see the rebuilt Kugelfischer injection pump hanging off the housing.
That engine is looking really good indeed!
That injection pump drive seems a bit odd, a belt in oil covered area? What material is the belt made from? I think I have never seen such a construcion before...
Anyway keep up the good work, this is really unique for the quality of the details.
-Wales
It's basically ready to go in the car.  I will not put the intake manifold on now because the chains from the factory hoist bar chafe it so I'll put them on once it's in the car.  The distributor/oil pump drive has to be properly oriented before assembly (and retained by the distributor collar or it will fall out when the engine's upside down).
In between a major bathroom renovation and other home plumbing tasks, I managed to install the new distributor (M50 curve, KF2 spec of course), plug wires, water pump and its famous 1280.01 unadjustable Ventiflex belt.
The hood has been removed in anticipation of the upcoming engine installation.  Ready to go except for me moving the unlicensed smart out of the garage, moving the engine from its stand to the hydraulic crane, mounting the clutch driven disc and pressure plate, then mounting it.  I'l have to wait for a day when my eldest daughter is available.  Maybe the next couple of days, maybe a bit later.  The green tape and padding are some of the precautions I have employed to protect the paint from damage when removing the hood and installing the engine.
