Mike T Posted October 2, 2018 Author Report Share Posted October 2, 2018 Thanks to Harm (that's his nickname!) in the Netherlands for finding these original Jaeger sports instrument panel warning lights! I just got them today. L to R: - low fuel pressure (KF/KF2 engine) - low brake vacuum / low brake fluid level - low oil pressure - main/high beam warning light - turn indicator warning light Now all I have to do is make a panel to hold the 6 gauges and these lights, paint it....oh and rebuild all the instruments, which likely need a refresh. Quote Link to comment Share on other sites More sharing options...
Mike T Posted October 8, 2018 Author Report Share Posted October 8, 2018 Today I got the beltline trim installed on the driver's side. With some help: my youngest daughter put the nut that holds the rearward part of the front fender trim on - that is only accessible with the front door opened about 45 degrees, because even like that, there is about 3 mm of space to play with to get the sucker spinning on the captive bolt that's attached to the stainless steel trim. All other connections are easy. My other daughter did the passenger side a couple of months ago. My fingers are too big to get in there properly! Quote Link to comment Share on other sites More sharing options...
Harry K Posted October 10, 2018 Report Share Posted October 10, 2018 If a car had feelings, it would feel like finally getting dressed again.(404 error) My wife always said she feels naked without her earrings on. Looking good Mike ! Quote Link to comment Share on other sites More sharing options...
Mike T Posted December 2, 2018 Author Report Share Posted December 2, 2018 Some recent work on the 404C, last weekend and just today: Clearcoat on the Carrosserie Peugeot plate. For reassembly, I used the original insulation as a template to cut Dynamat Xtreme panels, mounted the Dynamat and then glued the original insulation to it. Heater core with the ancestor of modern "set and forget" heat level - thermostatically controlled water valve. Heater core box is mounted in the car with new foam to seal between the air intake in the bodyshell and the bakelite box. Wiper mechanism mounted - both spindle assemblies are brand new. Quote Link to comment Share on other sites More sharing options...
Goce Posted December 2, 2018 Report Share Posted December 2, 2018 You'll doing a great job on the coupe Mike, i'm very surprised how many italian looking parts there are in it, thet heater looks like it will bolt straight in the little Niva i'm now fixing, also the wiper mechanism looks straight out of a zastava which is also a copy from Fiat. I'm surprised peugeot made them this way. Quote Link to comment Share on other sites More sharing options...
SRDT Posted December 2, 2018 Report Share Posted December 2, 2018 Pininfarina must have used many locally sourced parts. Quote Link to comment Share on other sites More sharing options...
Mike T Posted December 2, 2018 Author Report Share Posted December 2, 2018 The entire wiper mechanism and heater is exactly like that of the 404 sedan, so they're not locally sourced. The wiper shafts are longer though, but still made by SEV Marchal. The heater is by SOFICA. Quote Link to comment Share on other sites More sharing options...
Mike T Posted December 2, 2018 Author Report Share Posted December 2, 2018 Together at last: 6 Jaeger France gauges in MPH and degrees F ( but the oil pressure is in bar - luckily I am bilingual ) plus the 5 original warning lights that make up part of the sports instrument panel for the 404 Coupé and Cabriolet. Now I have to get two or three of these gauges refurbished and have a metal plate to hold them made up. Quote Link to comment Share on other sites More sharing options...
Mike T Posted December 3, 2018 Author Report Share Posted December 3, 2018 Voilà! Wiper nozzles mounted. Tough to get those on a C after the heater unit is in. On a sedan it's no problem Quote Link to comment Share on other sites More sharing options...
Goce Posted December 3, 2018 Report Share Posted December 3, 2018 Someone must have copy someone else, i don't have good picture to show you but you can see this is a Niva heater core, little more crudely made but they may be interchangeable, also the box looks almost identical. Quote Link to comment Share on other sites More sharing options...
Mike T Posted December 3, 2018 Author Report Share Posted December 3, 2018 Not the same at all: the Peugeot rad has hard sides and it twice as thick. 404 was introduced 15 years before the Niva. Which in turn got its core from a Fiat 124. Quote Link to comment Share on other sites More sharing options...
Bean Posted December 4, 2018 Report Share Posted December 4, 2018 Great progress Mike! Looks fantastic. Rabin Quote Link to comment Share on other sites More sharing options...
Mike T Posted December 31, 2018 Author Report Share Posted December 31, 2018 When the 404C goes back on the road, it will be with this - its original instrument panel. I tidied it up yesterday - took it apart, cleaned it, repainted the fuel tank and temperature gauge needles. The car was sold when new in Canada, hence the MPH speedometer. The 120 MPH scale was particular to the Injection version. The car came with an alternator so the "battery" gauge is a thermal voltmeter. The sports instrument panel I have the equipment for will go in once the car has been on the road for a while. Quote Link to comment Share on other sites More sharing options...
Bean Posted December 31, 2018 Report Share Posted December 31, 2018 Did you do anything with the clock? I've got a 504 clock I took apart to see if I could either fix, or replace with a more accurate movement as the stock one lost 10m a day! Rabin Quote Link to comment Share on other sites More sharing options...
Mike T Posted January 1, 2019 Author Report Share Posted January 1, 2019 No I left the clock alone. Unlike the two other ones I have, the face of this one is not corroded and IIRC it works. These clocks were mechanical and had electric winders, which wind them all at once. Quote Link to comment Share on other sites More sharing options...
Mike T Posted February 4, 2019 Author Report Share Posted February 4, 2019 New rubber parts for the wiper motor: Instrument panel connected - the wiring as built in my car is very different than the wiring diagram: The instrument panel installed. Ventilator switch is now mounted on the dashboard rather than the SOFICA heater box: Quote Link to comment Share on other sites More sharing options...
Mike T Posted February 18, 2019 Author Report Share Posted February 18, 2019 The Dynamat party is over. Onto the electric washer pump (mounted under the dashboard) next and then the steering column + pedal box will be installed in a week or so. Quote Link to comment Share on other sites More sharing options...
Mike T Posted February 28, 2019 Author Report Share Posted February 28, 2019 Last bit of work done at Victoria Plating Ltd: The 4 holes that a previous owner had punched into the sill/rocker panel embellishment strips when the captive bolts rusted off decades ago were welded shut and the outside was polished so this patching work became invisible; the two upper rear fender trims were de-dented and then polished; cadmium plating on the headliner trim panels which are covered with soft headliner material. This was done because they could rust as the originals did and that distorts the fabric as the iron oxide builds up; and finally the hardware for the handbrake components under the car were replated in yellow cadmium. Quote Link to comment Share on other sites More sharing options...
Mike T Posted March 3, 2019 Author Report Share Posted March 3, 2019 Saturday the 404C seats and headliner (including the plated parts in the above post) went down to Rightway Heritage Trim in Highlands near Victoria BC. The headliner will be remade, the metal headliner trims will be also retrimmed, and the seats will be stripped, blasted, painted and reupholstered in a light grey natural dyed through leather (not embossed) tanned by the firm Hyde. I may get them back by June... Quote Link to comment Share on other sites More sharing options...
Mike T Posted March 14, 2019 Author Report Share Posted March 14, 2019 ...the seats will be fitted with heating elements..... And.... I bought a different set of rubber isolators for the wiper motor and drive, because it's in a colour that more closely matches the latex rubber original. The pale red ones in the photo will be used in the 404C and the others will be spare parts. All the red ones are in what seems to be silicone rubber so should handily outlive the originals. Quote Link to comment Share on other sites More sharing options...
Bean Posted March 14, 2019 Report Share Posted March 14, 2019 Will there be any need to upgrade the alternator at all? I know running an 80A unit in my '76 504 made a HUGE difference with EVERYTHING electrical related on the car. Rabin Quote Link to comment Share on other sites More sharing options...
Mike T Posted March 15, 2019 Author Report Share Posted March 15, 2019 Yes, that is part of the plan. In the 404 KF2, the alternator is buried deep on the exhaust side and can't be seen at all from above, so a non-original one will be quite OK. The original is 400W. I'm aiming for over a kW. Quote Link to comment Share on other sites More sharing options...
Mike T Posted March 16, 2019 Author Report Share Posted March 16, 2019 A spare new old stock window winder for the 404C. There are two good (I think they are!) used ones in the car, so this is my reserve. Quote Link to comment Share on other sites More sharing options...
Mike T Posted March 17, 2019 Author Report Share Posted March 17, 2019 I finally got the steering column mounted. Instead of the flector I used a Paulstra Septor for the pinion link. Quote Link to comment Share on other sites More sharing options...
Mike T Posted April 1, 2019 Author Report Share Posted April 1, 2019 The handbrake cable and control were assembled and mounted today, along with the pedal box. The worst part of the whole operation was discovering that the buttress under the driver's side, which is a Peugeot original, has a captive stud that is about 6 mm too short to hold the metal handbrake sheath under the driver's floor. So I had to remove the brass clamp and reduce its thickness by about 3 mm on both sides using a Dremel and files (good old engineering on this part, with massive redundancy) in order to get it on. The pedal box was dead easy of course and the stuff under the car was as well. Quote Link to comment Share on other sites More sharing options...
